stupid welding question
Discussion in 'The Hokey Ass Message Board' started by nashvegas99, Jan 26, 2012.
  1. nashvegas99
    nashvegas99
    Has anyone ever used the welding/splatter paper to put on their frames or other pieces they are welding to keep the slag off of the pieces? Yes, I'm using a small wire welder without gas and the slag splatters are terrible. I was curious if I used this stuff if it would cut down on the splatter a lot without starting a fire. i know it sounds stupid, but that's just the way my simple mind works. cant afford new gas welder. I've also got sticke welder but same thing happens. I must also say i'm a pretty new welder.
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
  3. readhead
    readhead
    Go to the welding supply and buy some anti-splatter to spray on the area around the weld. Makes it a lot easier to clean up.
  4. themoose
    themoose
    I have us it when repairing RV's to protect interior components such as dashes and upholstery. Worked good for me.As stated above anti-splatter spray will help clean up by keeping the splatter from sticking.
  5. Pete1
    Pete1
    from Wa.
    WD40 works a anti spatter spray in a pinch.
  6. Raven53
    Raven53
    from Irwin Pa
    YUp welding spatter spray works wonders, are you using a flux cored wire?
  7. the metalsurgeon
    the metalsurgeon
    from Denver
    agreed.
    my weekly metal work blog www.themetalsurgeon.com
  8. nashvegas99
    nashvegas99
    Yes its flux cored wire
  9. ctfordguy
    ctfordguy
    Hey,
    If my memory is working....WD40 is FLAMMABLE...Not what I'd like to weld around. I'm going to check on it when I get home
    Bruce
  10. Dane
    Dane
    from Soquel, CA
    Try experimenting with the distance between the wire tip to weld pool as it may help reduce the splatter some. Go for that smooth bacon frying sound. :D A good ground helps too.
  11. nashvegas99
    nashvegas99
    Thanks for the tips. Anything to help me better is appreciated. Do you mean it should be closer? Part of my issue is that when i was researching to buy a wire welder, all i kept hearing about was duty cycle this and duty cycle that. Granted i didnt buy a really expensive, but my mimd says go quick so the machine dont shut down
  12. Dane
    Dane
    from Soquel, CA
    " Do you mean it should be closer?"
    You want to experiment both closer and further until you hear a smooth sound like bacon frying. Practice on a clean flat piece of metal 1st until you get the hang of it. Once you get the sound right you should see less spatter, but you will never get rid of all of it. Also, once you get smooth experiment with wire feed speed and voltage to see what makes the least spatter.
  13. Mr48chev
    It makes pretty flames when it catches fire too. Not the greatest thing to use for that purpose.
  14. Atwater Mike
    Atwater Mike
    SILICONE SPRAY in a can. Welding shops even stock it. (just don't fill the air with it if you're going to paint something...)
  15. rusty rocket
    rusty rocket
    Paint doesnt like to stick to metal after being sprayed with wd40.
  16. Voh
    Voh
    I was told that you could use PAM cookin spray. Haven't tried it so I can't confirm it yet.
  17. jasper30
    jasper30
    from kansas
    Really soapy water
  18. Don't worry about your duty cycle. Concentrate on getting the best weld. As others have stated, listen for the sound, watch the puddle and get your technique down pat. If you exceed the duty cycle, have a cool one and let the machine rest. You're only likely to trip the breaker if you're cranked up and really pushing the machine hard.
  19. choppd27'Munster
    choppd27'Munster
    also with flux core it likes to be dragged not pushed when welding with it. that might help with some splatter, but flux is always gonna have alot of spatter, just the nature of the beast. you can try turning your wire down some with a lil more heat as well. remember flux runs different then lets say er-70 wire which is your standard wire you'd get for running with a gas welder, from any local shop.
  20. Black Primer
    Black Primer
    I guess the paper works ok, but I've only seen it used on windows and mirrors. Big truck body builders use it to keep spatter off them while welding. These are generally verticle surfaces. I don't know how it would work if the sparks laid directly on a horizontal surface.
  21. keithreid
    keithreid
    unless you are burning a lot of wire over a fairly long time, duty cycle won't mean much.
    50% Duty cycle means that the machine is rated to run for 5 minutes out of 10. For most home/hobby welding, that's not going to be exceeded.
    To get less spatter (you probably won't get to none with flux core), try a different wire size(if possible), and different arc lengths. You might also try different amp settings. It wouldn't take too long to experiment with these 3 things on a piece of s**** to see you can cut down on the amount of spatter you have to clean up.
    Y'all have a good day, Keith
  22. nashvegas99
    nashvegas99
    HereAre the ugliest welds you will ever see. They are strong enough to take a licking from the sledge bfh. Advice and comments appreciated. Was the white fluffy stuff the flux burning off on the back of the welds? I cant post pics from my iphone (at least i dont know how yet). Will get them on here in a few
  23. nashvegas99
    nashvegas99
    Can i email them to someone and you post them for me? If not i will have to do it tomorrow at work
  24. thorpe31
    thorpe31
    from nor-cal
    Are you using DC Straight Polarity (the electrode will be negative) and is the ground clamp clean,tight and on your work?
  25. nashvegas99
    nashvegas99
    Not sure of that. It came ready to weld
  26. Cerberus
    Cerberus
    I used the welding and spark deflection paper by 3M to protect the dash when mig welding the floor of my '56 DelRay. Had to weld up the shift linkage hole the PO made for the M21 because I installed a TKO600 5-spd which requires a different location for the shifter hole. Also, I have welding blankets I covered the rear seat with. You do not want sparks to contact the gl*** either.
  27. hidez57
    hidez57
    that's a 10-4 on that. cheaper, too.
  28. repairmanrod
    repairmanrod
    from colorado
    I agree totally.......the cored wire will need to be ran electrode negative. You will encounter a lot of spatter BALLS all over your weld and the weld will not look right either.
    <!-- / message -->
  29. nashvegas99
    nashvegas99
  30. nashvegas99
    nashvegas99
