1952-59 Ford Sub Frame matted to 55 Fairlane
Discussion in 'Off Topic Hot Rods & Customs' started by 55newbie, Jun 23, 2018.
  1. 55newbie
    55newbie
    from Ohio
    Years ago I had a 55 Chevy truck that I had a 77 Camaro sub frame welded on. This gave me front disc brakes, power steering ect. This was pretty common to use 70's camaro/firebirds as donors. It was the right width, so no issues. Worked great. My question is, is there a 70's or 80's car that I can weld onto the front of a 55 Fairlane to give me the same effect.
  2. squire g
    squire g
    i would imagine any late model truck's front end could be cut and the rails matched up some how. maybe a ranger if not a f150. you could even get a 4wd truck and never get stuck in the wet gr*** at the car shows
  3. Bleach
    Bleach
    Nothing's wrong with stock steering geometry and brakes on my 56. I like driving it like it is.
    danman55 and mikhett like this.
  4. bskustoms
    bskustoms
    from Aloha, Or.
    I mated the '70 olds cutl*** to my '56. Also put in the 455 olds with it Runs stops just like a hi-po cutl***, but with a cooler looking car.
  5. 56longroof
    56longroof
    Thete are plenty of options for the stock set up. With a complete front suspension rebuild including steering box and Aerostar coils. It will surprise you how well it will drive. Add in a front disc conversion if you feel the need and you'll be ready to go.
    JeffB2 likes this.
  6. Texas57
    Texas57
    There was a 55 (?) Mercury top notch build running around Phoenix that used a late model Dodge Dakota front clip to allow instalation of a 4.6 dohc Ford. Saw him at Goodguys and the Pavilion cruise back 3 or so years.
  7. mikhett
    mikhett
    from jackson nj
    I. Rebuilt my stock suspension on my 56.Im happy with it.
    danman55, Bleach and JeffB2 like this.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Bleach likes this.
  9. Bleach
    Bleach
    Yes plus the huge three spoked thin rimmed steering despite no power steering makes steering very easy.
    It reminds me of a large industrial gate valve.
    danman55 likes this.
  10. koolmercuryman
    koolmercuryman
    from iowa
    The first thing I do to all my old Mers is shorten steering column 2 inches
  11. Roothawg
    Roothawg
    Man my 55 drives as good as my new Lincoln. As stated above, don't subframe it. I am doing a subframe on a 58 Chevy pickup right now. It's a ton of work.
  12. 55newbie
    55newbie
    from Ohio
    Thank you. I'll try this before I opt for major surgury
  13. bobss396
    bobss396
    I may do the Borgeson conversion to my '59, but all rebuilt it steers well for a manual box.
  14. Edsel58a
    Edsel58a
    If manual steering is wanted and your box is bad, a Maverick box about bolts in
