sub rails for channeled car- lets see how you did it
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jan 31, 2011.
  1. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
  2. gtkane
    gtkane
    My frame was narrow enough that I could slide the body over it. I used 1" square tubing to raise the floor 4 or 5 inches(can't remember)...
    Then I wrapped it in 18 guage....
  3. Excellent stuff here!
    please keep them coming
  4. Bump for more cool stuff
  5. Metal work and design wizardry bump
  6. clockwork31
    clockwork31
  7. slepe67
    slepe67
    bump, why not. this thread has some great info, please add to it!
  8. Kirk Hanning
    Kirk Hanning
    Here's a 34' sedan that's channeled 5". Make a subrail to fit the contour of the ch***is then brake/shrink a set of rockers, square up the body to the rockers while maintaining the door gap done. I suppose it's really easy if you start with a car that is rusted out the first 1' from where the bottom would be!
    kidcampbell71 likes this.
  9. This is my Model A I'm building now. I used 1/2"x1" tube for the subrails and 18ga cold rolled for the floor and tunnel.
    29EHV8 likes this.
  10. TexasSpeed
    TexasSpeed
    from Texas
    Perfect!! I was struggling with brainstorming up how to channel my coupster while preserving my subrails and the original floor. One of my goal is reusing as much of the original body as possible without resorting to new sheet metal and tube steel. You did a great job handling that. This is definitely future reference material for when I finally get to that point in my build.
    iPhone - TJJ App
  11. Inland empire hot rods
    from so cal
    nice work, thanks for the ideas
  12. slepe67
    slepe67
    Great stuff!!!
    Ttt
  13. oj
    oj
    Why 'subframe'? I am using 16ga to create a structural floor - think 'unibody'. The seats in my modified are below the top of the frame rails.
    29EHV8 likes this.
  14. slepe67
    slepe67
    Thats awesome!!
    Ive tried starting that topic in here elsewhere. I saw a Rod & Custom where they did that to a 33 coupe. I want to do it to my 32 5w. This thread is making my brain work overtime and i thiink i know how to do it. I just need talent :)
    29EHV8 likes this.
  15. oj
    oj
    Talent? Thats what the 'showoffs' have, the rest of us make due with what we got - desire trumps talent every time in hot rodding.
    D-Russ likes this.
  16. clockwork31
    clockwork31
    That is exactly what I plan to do, finally an example ! thanks for sharing!!! Wow! good job!
  17. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Very nice work, this is what I am trying to do with our build. I really didnt see need for a tubing frame for the floor either. Its going to get its strength from the bulkhead/firewall behind the seat, the frame K-member, driveshaft tunnel, and toe board. Its gonna be a combo of 16 and 18 ga steel.
    When I get the inner rocker panels and the support that sits on the k member done, I will post more pics...
    29EHV8 and kidcampbell71 like this.
  18. slepe67
    slepe67
    For everyone, more specifically coupe guys:
    I get how everything forward of the seat goes together, be it uni-body or steel tube frame.
    I've got a 32 5W and am kicking around the uni-body thing...Could a guy buy a new 32 roadster REAR floor, and bolt it in, and weld that to the body with extension tabs? The front looks self explainatory...I'm thinking too much again, arent I?
    29EHV8 likes this.
  19. brainfreeze
    brainfreeze
    gonna drag this up from the depths cause it rules! so much good info!
    29EHV8 likes this.
  20. travis?
    travis?
    also bumping this, because this is where im currently at in planning, the more info the better
    awesome work guys
  21. meltedpiston
    meltedpiston
    Bump for the guys that bought bodies with no sub floor what so ever and 4+ inches of rot on all your lower sheet metal panels haha.
    29EHV8 likes this.
  22. brianf31
    brianf31
    I used a slightly different approach than the Z bend. I used two hard points at the outside bottom of the frame rail, bolting to brackets added to the A and B pillars. Most of the body load is carried through those points.
    An inverted 16 ga L-channel was used on top of the rail. Channeled Subrail.jpg
    The L-channel was welded to the A pillar, B pillar, cowl and wheel housing. I bent up some more 16 gage for transverse floor crossmembers and welded that to the top of the L channel. I then closed it all out with 20 gage sheet. Old rusty subrails were cut down and used to close out the bottom of the door opening to the L channel.
    29EHV8 and 31Vicky with a hemi like this.
  23. nice to see an old thread come back up.
    for you visual guys, Eastwood has a video to watch
    29EHV8 and gnichols like this.
  24. Great old thread! Lots of cool builds and tips in here.
    Anyone have anymore to share?
    -Shiny
