subframe help!
Discussion in 'The Hokey Ass Message Board' started by THE CHIEF, May 12, 2009.
  1. THE CHIEF
    THE CHIEF
    from MIAMI
    i started clipping my Pontiac, got everything mostly done and i went to re check the squaring on the frame, b4 i started cutting anything i checked the measurements on X and wheelbase,the wheel base is 120" when i measure it on x for squaring it gave me from the rear driver side tire to the front hub 136.75 and from the p*** side rear hub to the driver side front hub 135.5, when i moved the who spindle on the front p*** side i saw that is was all lose so i thought that was why the measurements was difference so i cut it. the car shifted a few times since we cut it so we made new marks so now after we cut the front end after we mark the wheelbase at 120" on both sides, after that we went and did the measurements on X again an from the p*** side rear hub to the front 120 mark is dead on but from the rear driver side hub to the p*** side 120 mark its of by 3/4" what can i do to fix this here is drawing of the frame wit the measurements. thanks in advance
  2. Atwater Mike
    Atwater Mike
    Take some basic measurements at points on the frame. 'X' from left front to right rear, at factory holes. (they were drilled there for body shops to check for 'diamond-shape' after accidents) When satisfied the frame is 'square' (rectangular, actually) now measure the rear axle for lateral (side-to-side center) and diagonal. (spring center bolts broken, very worn shackle bushings, brackets bent, or frame bent from rear end trauma on one side) You will find the error.
    When you do, take time to set everything up in a sort of temporary jig. This can be some diagonals of inexpensive 3/4" black pipe from the plumbing supply. Cheap, welds good, and is very strong 'til the whole subframe is securely tacked, checked, then welded.
  3. THE CHIEF
    THE CHIEF
    from MIAMI
  4. THE CHIEF
    THE CHIEF
    from MIAMI
    no one has any other thoughts
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    What clip are you using? Some GM cars had the front tires oddly displaced from each with a different wheelbase on either side.
  6. THE CHIEF
    THE CHIEF
    from MIAMI
  7. To Tall
    To Tall
    check your rearend mite be off 3/4 (use the holes in the frame)
  8. Larry T
    Larry T
    Looks to me like you need to take some measurements on your frame, not your hubs. If they check out right you can go to your axle and suspension.
    Larry T
  9. THE CHIEF
    THE CHIEF
    from MIAMI
    ill give the me***uring from points in the frame a try, but if the frame thoes have a slight bend how would i got about it
  10. HemiRambler
    HemiRambler
    A parallelogram would have measurements as you describe.
  11. palosfv3
    palosfv3
    Wheel length measurements are best when taken from the lower front ball joint grease ****** to the rear axle control arm front mounting bolt centerline or the rear leaf spring front mounting bolt centerline . If the rear frame section has reference holes near these points they can also be used. Do not measure from the center of the spindle to the rear axle shaft center. Check your cross measurements from these same reference points.
  12. Yes, you must find reference points on the frame. If you get it within 1" you should be good to go with a wheel alignment when your on the road.
  13. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    measure from the upper shock holes. measuring from the hub is a no go due to differences in alignment, and control arms. (think about every time You bump a car-stop at the grocery store. now multiply that by 30 or so years. )
  14. 55 dude
    55 dude
  15. THE CHIEF
    THE CHIEF
    from MIAMI
    i haven't been able to work on the car, tomorrow i will try it again, i want to thank everyone for the help and the great advice
