Technical Substitute for brake fluid (demonstration purpose)
Discussion in 'The Hokey Ass Message Board' started by Dan, Dec 6, 2017.
  1. Dan
    Dan
    I want to demonstrate how to bench bleed a master cylinder to the students. I hate using brake fluid for this as it's messy, expensive, etc. Can I use something like rubbing alcohol or denatured alcohol to do this? This would be a master being used for demonstration and not to be actually used. If I had a car that was ready for a master swap we would just do it as normal but that is not the case.
    Any thoughts, ideas? Thanks-
  2. Bird man
    Bird man
    from Milwaukee
    Olive Oil.
    dana barlow likes this.
  3. Kerrynzl
    Kerrynzl
    This^^^
    All the Gamers [on computer simulators] use cooking oil in their hydraulic brake servos
  4. HOTRODPRIMER
    HOTRODPRIMER
    Denatured alcohol might damage the rubber seals,colored water is cheap. HRP
  5. george d gabert
    george d gabert
    mineral oil, biodegradable and similar consistency and collor
  6. squirrel
    I would try water. Cheap, easy, non toxic. And it's soluble in brake fluid.
    1964countrysedan likes this.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Most racing bicycle hydraulic systems (yes, hydraulic brakes have arrived on bicycles) use a mineral oil. Cooking oil such as olive oil will do and clean up is easy. Plus it will leave your skin baby-soft and squeezable.
    mgtstumpy and kadillackid like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    yup mineral oil is what is used in the hydraulic brakes on go karts....
  9. AVater
    AVater
    Would the pink RV antifreeze work? Non toxic, cheap and easy to clean up. (Propylene glycol).
    tb33anda3rd likes this.
  10. wisdonm
    wisdonm
    Any liquid will work since there is no heat or cold involved. Water is the most benign and can be colored if necessary.
    Oils may be hard to clean out and expand when heated.
