Technical such thing as a 392 hemi industrial?
Discussion in 'The Hokey Ass Message Board' started by hemi rodder, Jul 10, 2014.
  1. George
    George
    Actually the plan was for the NYer to get the long tails & the NYer Deluxe & Imperials to get the short tails in '54.
  2. George
    George
    In '56 the Poly would have been 331 & I think the extra small holes with the pushrod holes indicate it's for a Poly, Some have speculated that 354s bored to 331 may be warranty replacement engines.
  3. Mr48chev
    No idea of what size this one is but it's kinda cool. It has sat out in front of a local wind machine manufacture for years as their lawn ornament. No doubt it did duty in an orchard for a number of years. Hemi powered wind machine.jpg
    Hnstray likes this.
  4. BJR
    BJR
    An easy way to paint the raised letters on valve covers or license plates is this. Spray the letter color with base coat and then clear coat it. Then spray the field color with base coat and take a rag with reducer and wipe the paint off of the raised letters. You can finish the tricky parts of the letters with fine sandpaper, just don't sand through the clear. Then clear the whole part and you are done. Here is an example of a Heintz Gullwing pop cooler I did. The raised part said Pepsi-Cola. DSCN1225.jpg
    Hnstray likes this.
  5. DDDenny
    Always thought these were cool too.
    How would you like to be the guy that had to R&R two iron hemi heads on this one.
    Just Gary likes this.
  6. willys36
    willys36
    All I have ever heard or read is only 331s and 354s were used for Industrial engines. And that 354s were by far the most prevalent. I have never seen a 392 in that use.
    I am really intrigued by truck heads for hi-po use, especially for 331s that have no end water ports. Neither do the truck heads. That makes them attractive for drag racing engines which don't use those p***ages and need them blanked off.
    Benefits I see of truck heads;
    big exhaust ports
    hardened exhaust seats
    big valves
    no crossover water ports
    no exhaust pre-heating p***ages
    Negatives for truck heads:
    have fat sodium filled valve stems, need new guides.
    have tall hot water intake manifold p***ages, don't work with p***enger car manifolds.
    Here are pictures of truck head features
    No water ports in ends
    Big ports, hardened seats
    No Siamese heat riser exhaust p***ages in exhaust ports
    Big exhaust ports
    hot water pre-heat port too tall. Easy to fix by brazing in a partial blocking plate
  7. bostonhemi
    bostonhemi
    [​IMG][​IMG][​IMG]Here is a few more pics of the marine heads even though I was told is came out of a truck. The tabs from the intake seem extended to cover those center ports.
  8. guffey
    guffey
  9. George
    George
    that's the truck intake, the marine intake looks bolt together. I have truck heads with the square crossover instead of tall.
