Suggested reference material for the 32 Ford
Discussion in 'The Hokey Ass Message Board' started by lintmann, Jun 27, 2010.
  1. lintmann
    lintmann
    from calgary
    Being pretty green when it comes to the 32 ford I was wondering if you guys could suggest some good resources(reading material or links) for me to learn from.
    I'm mostly interested in what they were like originaly. I'd like to take my 32 5W and basically restore the body sheet metal and body mechanicals to original before rodding the rest of it. Knowing proper sheet metal repair and panel replacement of this old tin, wood replacement as well as how to install the roof insert and basic interior are just a few of the things that I'd like to learn.
    Thanks.
  2. Harrison
    Harrison
  3. lintmann
    lintmann
    from calgary
    Thanks JH, I'll look into getting that one if you think it's worth while.
    For the most part I'm okay with most body, paint and mechanical issues. Where I think I'll have issues is with things that are specific to the 32. An example is the common sheet metal cracking in the body line below the rear quarter windows. I would normaly just weld them up but I was told that if I do that it will just crack again and that I should make new pieces and weld them in. I don't know if this is 32 specific(design of the body line) or just because of the type of metal they used back then but this is the kind of thing that I'm talking about.
    I guess I could just ask every time I have a question but I thought it would be better to read up on the basics of "doing" a 32 first so that I can at least ask inteligent questions.:)
  4. green53ford
    green53ford
    from Wisconsin
    The 1932 ford book by DAVID G. REHOR.
  5. Andy
    Andy
    That is a common crack. The others are the crown beads of the fenders. The best reference book is the new two volumn set from The Early V8 Club. Amazing amount of info. Nothing else is close. I will try to attach a link later.
    I sure would not add a piece just because it is cracked.I would remove interior parts untill I could weld it from inside. Should be an easy weld and the heat will normalize the area. I would gas weld.
    https://www.earlyfordv8.org/store-product-item.cfm?id=15&pid=2
  6. tommy
    tommy
    This is my favorite but I haven't kept up with all the new publications. I see that it is now available again but keep your eyes on Ebay.
  7. thunderbirdesq
    thunderbirdesq
    How about www.fordbarn.com lots of sharp deuce guys over there, especially in the realm of stockers.
  8. If you are "doing" a '32 (is this anything like "doing" the lady next door?) I think that Dave Rehor's book and "The V8 Affair" would both be a waste of money. Be sure to look through them before you spend the money. If you intend to restore a '32 (or make a good resto-rod) then Dave Rehor's book is an absolute must. I was very UNIMPRESSED with the book "The V8 Affair".
    Charlie Stephens
