Suggestions for a 34 radiator
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Feb 17, 2014.
  1. hotrodderhaag
    hotrodderhaag
    I'm running a 3 inch channel job on my 34 ford with a flathead .
    Who should I order a radiator from. Many company's are not offering a 3 inch chop on one . I don't want a cheap o flat radiator. I want one with the correct tank on top
    Any help?
  2. MAD 034
    MAD 034
    from Washington
    Could you have a radiator shop cut 3"out of the core of an original radiator and make it work? My car is channeled 6" and running a deuce grill/Walker radiator so no help there.
  3. fredb
    fredb
    Might check with Br***Works (HAMB Alliance member and great guy). Quick and excellent work.
  4. alchemy
    alchemy
    Won't Walker custom make a short one for you?
  5. Chuck R
    Chuck R
    i used Mattson, they will build it exactly to your needs. Full custom sizes and mounts. They built me a very custom sized radiator for my 34.
    http://www.mattsonscustomradiator.com
    Stanton, Ca
  6. hotrodderhaag
    hotrodderhaag
    ive checked several companies. not to many were wanting to do a chopped flathead 34 radiator with the correct brackets. and to get one close, that i could have someome modify, im looking at over 550$. so i was looking around on ebay and i may buy one made for a SBC that is chopped, with generic brackets. they are cheap.. if im going to have to modify it a bunch, i mise well start with a cheaper core!. i did pick up an orignal top tank mount for the rad support rods, this will make sure the grill and hood rods are in stock location and i can fit the radiator to that along with my grill mounting tabs. adding water inlets and outlets is cake work, so thats no worry. im also going to trim off the side mount filler neck and put it on top where it belongs
  7. HOTRODPRIMER
    HOTRODPRIMER
    You can take my opinion with a grain of salt but....
    I know they are pricey but Walker Radiators have been building radiators for many years,,I have used most every ones radiator on the market today and finally came to the conclusion that Walkers are the most trouble free and correct looking radiators on the market. HRP
  8. hotrodderhaag
    hotrodderhaag
    walker wont chop one..my 34 is channeled. i love a br*** radiator but i was told by customer service that they dont do it. are they incorrect ? has anyone seen other wise?
  9. HOTRODPRIMER
    HOTRODPRIMER
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
  11. hotrodderhaag
    hotrodderhaag
    $900 on a walker, i just cant make that happen.
    im going to have to go aluminum. im not building a show car, im building a car to drive to bonneville. so aluminum is ok with me.
  12. HotRodMicky
    HotRodMicky
    So, who does an aluminum radiator chopped 3 inch for a 33-34 ?
  13. chopolds
    chopolds
    from howell, nj
    Try C.A.R.S ( Custom Auto Radiator Service) in NJ. They custom build them from scratch and probably will do it. You might have to send them drawings/measurements though, for a chopped radiator. Been using them on all my builds for 25+ years.
    They built one for a 34 Terraplane from scratch for me, will everything I needed on it (trans cooler, AC condensor, sensor bungs). Not cheap, but very well done!
  14. hotrodderhaag
    hotrodderhaag
    My biggest thing with the radiator is, the entire proper alignment of the hood and inner fenders and the body depends in a correctly positioned grill on a radiator. So I was hoping to get a bolt On unit such as walker or br*** works.
    I'm going to make a few calls today and see what I can come up with .
  15. alchemy
    alchemy
    I talked with the Br***works guy on the phone once about custom making a radiator for my weird application. He sounded like he could do it and the cost wasn't too much more than the Walker standard stuff. If all you need is a '34 that X inches shorter, it should be easy for him to construct, right?
  16. hotrodderhaag
    hotrodderhaag
    im calling him today, thanks for the info!
