Projects Suggestions for a REALLY low profile air cleaner
Discussion in 'The Hokey Ass Message Board' started by Kerry, Aug 10, 2011.
  1. Kerry
    Kerry
    I've been swapping a newer 360 magnum engine into the 59 Plymouth suburban. With the engine in place using the stock mounts and the aftermarket air gap 4 bbl intake it puts the air cleaner a lot higher. Not sure how I'm going to be able to keep it under the hood. I was trying to keep it looking like an early sixties car so a hood scoop would probably look wrong. That and I'm not wild about cutting a hole in the hood. I might not have a choice
    Any suggestions?
  2. squirrel
    Find a different intake.
  3. Kerry
    Kerry
    This is a 1995 magnum engine. The only 4 bbl intakes are air gaps. That and the HAMB drags are upon us and I need her to pull the digger.
  4. Slick Willy
    Slick Willy
    What about one of these style jobbies?
  5. 35touring
    35touring
    from Kentucky
  6. LowKat
    LowKat
    I used an aftermarket dropped base with the top half of a 383 dual snorkel on one of my old projects. Ended up being too low and had to use a 2" riser to clear the radiator hose.
  7. 53sled
    53sled
    from KCMO
    olds 455 toronado, and probably the 307 models too. I got one I think, if I find it, you can have it.
  8. domepiece
    domepiece
    not sure how much room you have but i've made them using a one of those triangular edelbrock air filter and cutting it up and just putting it inside the base of a small round filter base.
