Technical Suggestions for belts & pulleys?
Discussion in 'The Hokey Ass Message Board' started by SDS, Aug 9, 2022.
  1. SDS
    SDS
    Close to having this thing on the road, getting down to the details.
    Looking for simple pulleys, preferably new as well as alternator & water pump belts. This is getting tough to solve in a cl***ic way.
    32 Ford Roadster
    327 Chevrolet engine
    So-Cal speed alternator bracket (high mount, right side)
    No other engine mounted accessories
    Thanks in advance,
    Scott
  2. Budget36
    Budget36
    I don’t recall if there are different pulleys for things when using a short or long water pump, other than the water pump pulley is different.
    You’ll only be running one belt though, right? Ie around the crank pulley around the water pump (both fixed positions) around the alternator (adjustable for tension.
  3. SPEC
    SPEC
    Vintage Air sells short water pump pulleys. Long water pump pulleys won't work they are deeper.
    scotty t likes this.
  4. 19Eddy30
    19Eddy30
    from VA
    Having a stash of GM brands pulleys from 50s - mid 80s help,,,
    Try 1966 250 6 C10
    Monza v8
    Novas 6 cylinder models
    63-72 non power
  5. choptop40
    choptop40
    Lots of short pulleys stashed in garages...Hambers got gazillions im sure..may make sense to buy new if you got the bucks...
  6. goldmountain
    goldmountain
    Start off by getting a ZIP's hi rise water pump setup.
    old chevy, Just Gary and jimmy six like this.
  7. 19Eddy30
    19Eddy30
    from VA
    Yes Recommend also , Zips
    Op will still need afew different pulleys & usually shims & extra gaskets
    (for shimming purpose)
    My Zip set up uses different pulley combo then my short water pump set up ,
    crank , water ,alt
    Just Gary likes this.
  8. SDS
    SDS
    Yes, it's a short water pump and yes, only one belt (duh, bow head in shame).
    ***uming both pulleys only need one groove. Will check out Zips - thanks
  9. Budget36
    Budget36
    Just to refresh my mind, both a long pump and short pump, the belt still rides in the same location, right? It’s just that the depth of the pulleys are different.
    I guess I mean crank pulley and alternator bracket make no difference?
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Not really. The short pump cars ran a flat no offset pulley on the balancer and the alt or generator was mounted on the outside of the exhaust manifold. The long pump cars the alt was further forward on the front of the cylinder head. These ran a dished pulley on the balancer and the belt ran about an inch and a half further forward
  11. Budget36
    Budget36
    Good info, so for @SDS he will need to know what alternator bracket he has, and get the proper crank pulley.
    Moriarity likes this.
  12. DDDenny
    Wrecking yard (good luck), swap meet, or vendors like the previously mentioned Alan Grove or Cl***ic Industries.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    I don’t know how that alternator mounts. But there are plenty of reproduction corvette pulleys available
  14. SDS
    SDS
    See my opening post - it's the So-Cal one (for heads with no accessory bolt holes) that mounts the alternator up by the right valve cover.
    I found that speedway makes a set for $87 and Summit sells them separately for around $30 each. Guess I'll try them
  15. Budget36
    Budget36
    I did read it, but as Mark mentioned short v long WPs use different mounts. I don’t know which the Speedway is made for. I guess if knowing that, you could work from there.
  16. SDS
    SDS
    Didn't think there was really much of an option with a SBC in a 32. It's a short pump.
    The So-Cal alt bracket looks like this...
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, looks like the same flat balancer pulley and water pump pulley that came on almost every 283 and 327 ever made
  18. big duece
    big duece
    from kansas
    I might have a pair of pulleys to work with the Zips water pump. Water pump and crank pulley.
  19. 19Eddy30
    19Eddy30
    from VA
    What Im saying is Just a match set for a single belt short water pump Application Might not line up for yr set up , there are different death bottom & top pulleys, ( short pump)
    I Believe the OP is going to run a hood ,
    A Monza V8 short pump will put Alt
    Between PS valve cover & thermostat,
    Then it will depend on aluminum intake used & heads ,
    Then if a Zip used different pulleys ,
    (Zip puts the fan more in middle of radiator)
    then another problem sometimes to pay attention to is lower rad hose to belt Clarence ,
    I Believe Zip instructions have a ""recommendation"" for what year and GM part numbers to use , including aftermarket replacement hoses,
    One of the short pump I used a 71 Buick
    455 water pump pulley
  20. el Scotto
    el Scotto
    from Tracy, CA
    One thing to keep in mind with the short water pump stuff is there's actually a few different depths available on the water pump pulley.
    I had never run into this problem for the 20 years I'd been fooling around with old cars until the one day I did. Then again on the next car/engine! Twice in a row...
    Nothing you can't fix with a press, though.
  21. 19Eddy30
    19Eddy30
    from VA
    ^^^ X2 or a bottle jack under truck hitch.
    Driver50x, texasred and Algoma56 like this.
  22. TA DAD
    TA DAD
    from NC
    Short water pump, stock crank pulley and Allstar products View attachment 5480619 [ATTA IMG_0374.JPG CH=full]5480619[/ATTACH] IMG_0366.JPG wp pulley with homemade brackets.
  23. 19Eddy30
    19Eddy30
    from VA
    ^^^ To wide for 32 ford under a hood,
    OP probably knows he can make something work sounds like he wants a Direct Bolt on, most of time modifications required.
    TA DAD likes this.
  24. squirrel
    Water pump uses 3905995 pulley
    Crank uses 3755820 pulley
    These are commonly available from all the restoration parts places, fit most V8s from mid 50s to late 60s.
    Don't overthink it, just put stock parts on, and be done with it.
    Stu, hendrcs, Moriarity and 4 others like this.
  25. DDDenny
    This fits with the hood closed on my roadster.
    TA DAD likes this.
  26. 19Eddy30
    19Eddy30
    from VA
    Squirrel you are knowledgeable man and usually correct but in this situation you have to know 32s ,
    I believe Op using stock firewall , if motor in typical location with sbc on short water pump No mechanical fan can be used, & this is 1 Style short water pump , Will Not fit a 1932 with stock style firewall & radiator in Stock location
    There are several short water pump set ups from the factory EC508500-730C-4FB3-B4E9-0BA4D0F65FA5.jpeg
  27. 19Eddy30
    19Eddy30
    from VA
    Here are 2 32s one with short pump
    Blower SBC , I made ,
    Other 32 with zip
    & the other 3 32s I dont have a pic of
    Another zip set up with different pulleys then one in pic,
    The other 2 32s short pump both have different pulley combination then others
  28. 19Eddy30
    19Eddy30
    from VA
    DDDENNY , I know it can be down ,
    But the one posted in pic of 40ish or later would not work.
    Not trying to bust out the Op , in his build thread he states
    " Built a lot of cars , Not a 32 thoe "
    OP has put together a Nice Roadster ,,
    I do not think Op going to notch frame ,
    & OP has found out that parts do not just bolt on like Original 32 parts , & has used a 3d printer before making a part,
    I Would like to have One!!!!! (3D printer)
    But not For the parts the OP printed out for his 32 roadster ,,, I would 3D print hard to find / rare parts like the Buick Black Out tail lights (41) I think ?? !!
  29. 19Eddy30
    19Eddy30
    from VA
    In that pic ,the Alt bracket bolts to top end of head then goes over to a few intake bolts ,
    With out a Zip its almost impossible to use a mechanical fan with stock style firewall notched for PS valve cover & radiator in stock location unless you set your motor very high off the frame.
    or motor set back about 3 inches Father from front crossmember then most do.
