Technical Suggestions on AC in F-100
Discussion in 'Traditional Hot Rods' started by 1955 F-100 guy, Nov 5, 2017.
  1. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Looking for suggestions on who has installed a AC, Heat, defrost unit in their 1953- 56 Ford F-100 , has 302 engine, which unit worked the best for you. PICTURES please inside dash and engine area-- Thanks
  2. graveyardsledder
    graveyardsledder
    Vintage Air is what we install at our shop. They have many in box type installs and then custom applications. Other than somewhat vague instruction they are pretty easy installs
    gimpyshotrods likes this.
  3. AngleDrive
    AngleDrive
    from Florida
    What engine is under the hood?
  4. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
  5. BJR
    BJR
    He said 302 in the very first post! Read before replying.
  6. ryno
    ryno
    vintage air, great product and customer service.
  7. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Thanks went with the Vintage air the one that is made for that yeartruck nice clean look--
  8. manyolcars
    manyolcars
    Stay away from Old Air Products in Ft Worth
    partssaloon likes this.
  9. eberhama
    eberhama
    I put vintage air in my '56, and like graveyardsledder said, the instructions aren't exactly 100%. With some head scratching and some fiddling, it all goes in pretty well.
  10. fiftyv8
    fiftyv8
    from CO & WA
    I used a an early Mustang under dash unit in my 59/60 F100.
    Fitted in ok and still have the stock heater working.
    Mounted and fitted everything at home and then just took it to a shop to have it wired, piped and gassed.
  11. You will never regret using Vintage air. HRP
  12. 40Standard
    40Standard
    from Indy
    you can always call VA for help. I have a few times
  13. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    The problem now is can not use the cowl vent handle hits the drop down panel that is installed under dash, and can not install control panel the back wire terminals hits the ac unit and it sticks out 1 inch from the face of the panel--
    The problem is not the install it is all installed as far as it can go with the parts that do not come close to fitting--
    any pictures of this unit installed in your 1953-55 Ford F-100 and using the cowl vent handle and supplied control panel---- Thanks
  14. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
  15. OLDSMAN
    OLDSMAN
    You can never go wrong when using Vintage Air. They are a class act.
  16. okiedokie
    okiedokie
    from Ok
  17. okiedokie
    okiedokie
    from Ok
    I did not use the VA direct fit , just the compact unit fit where I wanted it. I could not use the vent handle either so I used an electric motor to operate the vent.
  18. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Did not fit as a sure fit unit for a 1953-55 Ford F-100 it was a challenge to install the control panel , ac duct hose to driver side vent, can not use their glove box supplied, could not use the cowl vent handle had to remake a extension piece to make it opens and close--- After all problems were resolved vintage air listened and helped in the problems and was more then satisfied with there help and response.
  19. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
  20. fiftyv8
    fiftyv8
    from CO & WA
    Sure fit and universal fit descriptions of products scares the hell out of me.
    Refer to my original post, take your time and go your own way.
    You will learn more and get a decent outcome.
    I like these as a start point at $75
    https://www.ebay.com/itm/New-A-C-Un...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    This similar to what I used but more expensive, I went for it because it looked a little more period correct in my truck and was Ford based...
    https://www.ebay.com/itm/1955-1956-...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    Hang in there and you will work it out.
  21. rdynes01
    rdynes01
    from colorado
    I think the word you're looking for is reputable and I've always found Vintage Air good to work with.
