I suggest you add a lot more information if you want an intelligible response. Do you mean the front or rear is rough? Solid front axle or IFS? Engine - big bolck, small block Do you kmow the current spring rate and shock rate? When you say coil over, by definition it is a shock and spring combined unit. Coil Over Shock
