Technical Suggestions
Discussion in 'Traditional Hot Rods' started by kenwood, Oct 29, 2025.
  1. kenwood
    kenwood
    from ne ohio
    I have a couple of questions.
    Number one
    Is there a better early (1957) SBC to early 39’ Ford transmission adapter? Or are they mostly the same?
    Number two
    Is there a better front motor mount system for an early SBC motor in a Model A frame?
    Lastly
    Is there a better center x member to use for the above setup? Closed drive shaft.
    Thanks in advance.
    Ken
    51 mercules likes this.
  2. DDDenny
    The short answer is "it's all been done", you will get a range of opinions, in the end you will still need to choose one, skill level is also a deciding factor.
    kenwood and alanp561 like this.
  3. 51 mercules
    51 mercules
    Number One; From what I've seen most of the Chevy to 39 Trans adapters are pretty much the same. i have a Cragar and my buddy has an Offy. They look identical.
    Number Three: My buddy bought boxing plates and a center crossmember from Dagels Street Rods. He's running a closed driveline.
    Deutscher, kenwood and alanp561 like this.
