Suicide Axle Tech???
Discussion in 'The Hokey Ass Message Board' started by TexasHardcore, Feb 24, 2004.
  1. What are the needed parts to convert a stock Model A axle to the front via SUICIDE???
    Anyone have pics/tech/info/suggestions?
    thanks
  2. DrJ
    DrJ
    Bubble gum Arc stick
    Bailing wire
    Rattle can of paint.
  3. Remove stock cross member, add 3" tube crossmember(Approx.) Make a flat plate, w/gussets. And for the real suicide, put the spring on top of the plate. use good bolts and add a plate on top of the spring to run the bolts thru. Pretty simple, and it lowers it pretty good. Maybe not the tru suicide way, but my version of it. Creeper
  4. Unkl Ian
    Unkl Ian
    Search the archives for "suicide".The subject comes up at least once a month.
  5. got any detailed pics of a front end?
    I'll be doing this myself, with the help of only a few guys who've never tackled such a job either. I need to know what parts I need to gather to perform such a conversion and where to find them.
  6. bradberry00
    bradberry00
    Here!
    Its been covered a few times, if this doesn't help use the search feature...youll find many more post on this topic...
  7. I have a ton of great ref photo's that I grabbed off the board (thank You). I'll share a couple...
  8. again...
