Hot Rods suicide door safety question
Discussion in 'The Hokey Ass Message Board' started by racer-x, Oct 15, 2015.
  1. Jalopy Joker
    Jalopy Joker
  2. I was at the pri show last weekend and spotted these on a blue 68 cuda. The owner said he got them from jerry bickle race cars. It was a very clean looking set up. They were on a car with regular opening doors. Im sure they would work in a suicide application. 20151211_144258.jpg 20151211_144354.jpg 20151211_144402.jpg
  3. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    most people on this thread haven't had a suicide door open at 60 mph on the freeway and rip the hinges to hell and smack the body of a really nice show car... Known 3 guys with that problem... seen the damage first hand.. Not pretty.
    05snopro440 likes this.
  4. Aviator
    Aviator
    What are the latches in post #23? Source?
  5. ago
    ago
    from pgh. pa.
    What if a unknowing p***enger bumps the door handle and the suicide door destroys it self. I have seen the end result more than once even with bear claws.
  6. Mr48chev
    Id think that it wouldn't be that hard to install a cable and pull handle setup and have the sign maker'pinstriper do a sign that says emergency crews pull here to release door pin as HRP suggested. You could run the cable exposed on the inside of the door panel and put something to grip on it where you cold reach it even if you couldn't move much. That way all you would add is the cable, handle and a couple of screw eyes to route the cable and maybe a pulley to make a smoooth turn to where it exited the body behind the door. Something like a parachute D ring with a magnet to hold it flat against the body shell.
    hipster likes this.
  7. Awhile back I had to letter and stripe a 34 3-window coupe.I wound up driving it to my shop to do the work.It had a setup in it that was essentially a sliding bolt system that employed a switch at the end that disconnected the starter unless the bolt was in place.Hand made I believe.
  8. swade41
    swade41
    from Buffalo,NY
    That sounds like a setup I have in the garage, it wires up to the neutral safety switch just like a shifter.
  9. AmishMike
    AmishMike
    Stimpy is right about NHRA rules - door open from outside. Had to replace doors on custom truck to run. For safety would want 1 latch to open. Dave MC ( post #25 ) appears to have good answer.
  10. Jalopy Joker
    Jalopy Joker
    for racing need a manual system. if there is a fire, or electrical shuts down, anything that relys on any type of standard switch will not work when needed most. having a warning light set up to warn that the safety pin is not activated would be good too. as porkn****** said, for a daily use of a "trick" spark plug, special gl*** break tool, etc would do the job.
  11. if you are conscious and not impaired. plan for the worst possible situation. that would be something thats manually operated from the inside and outside.
  12. Jalopy Joker
    Jalopy Joker
    for a safety door stop: rjracecars.com : door stop kit # 211502
  13. Jalopy Joker
    Jalopy Joker
  14. Rocky
    Rocky
    Classified Editor
    I have a pair of Vintique units for my 34 but hate the idea of them binding in a wreck......I run bear claw latches and the short dog chain attached to the front legs of my roll cage idea appeals to me.
    I was following "Donna" to the street rod nats in '88 when the p***enger door of her 32, 3 window opened at 70 MPH on the interstate. MAN! That will get your attention in a hurry! Ruined the door, rear fender , quarter and door jamb in a heartbeat. Good thing she didn't have a p***enger.
    I worked with a guy who was a kid riding in the back seat of his parent's 34 four door when the back door began to open. He grabbed for it, knowing his dad would beat his *** if that door came open....he was pulled out the door and rolled down a soft gr***y bank. He was unhurt but he still got his *** beat.
  15. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Watched my buddies sedan have that issue... his p***enger was quick enough to grab the door before it flew all the way back... but it can and does happen...
  16. WinDancerKnives
    WinDancerKnives
    First post here after first search. Got two ideas for the safety latch on the suicide doors on my 69 GMC pickup. Street only, but serious thought about "what if". The dog chain from the door to the dash is #1 for now. If mounted up high on the door and the top of the dash it would have some slack and be very noticeable to anyone outside the vehicle. Would hate to have the door come open on its own. #2 is the seat belt idea, maybe tie it to the driver's seat belt hookup somehow. Thanks to all for participating in this thread!
    Dave
  17. I haven't got to read this thread. But this is 20160114_134212.jpg what I have on my 34 delivery, a simple screen door hook. It is strong enough to keep the door from ever opening. And also someone, could open it in an emergency from the outside too. Ron...
    Dave Mc and CornfieldPerformance like this.
  18. chrisp
    chrisp
    Nobody will look for that tiny hook down there in a crash. Even you might not be able to release it if there is some tension on it.
    If you're in a burning car with jammed doors, you really want to get the hell out of there as fast as you can, I know that from experience...
    When I was driving a suicide door car, every time my wife or daughter would seat next to me I would lock their door because they were unfamiliar with it and more than once they grabbed the wrong handle to open the window.
    Best idea I' ve seen so far is the seat belt with enough slack to get people to notice it and cut it/unhook it.
  19. Chrisp , My idea is just something to keep the door from springing open. If it should twist, or a bump, like going over rail road tracks etc. My biggest concern was that the door or paint may get damaged. As for the safety goes, a 34 dodge delivery is not very safe. I don't expect anyone to unhook the latch in an emergency, or even know that they are even there. I just think that they would break off, if someone pulled the door open from the outside. I'm more concern with the way it looks , than of its safety. I think the seat belt idea is a better idea, but I just cant picture how it would look. And having to have a knife to cut it? I have a 56 Nomad with seatbelts that I take the family and grandkids in because of the safety factor. The delivery, like my A coupe are just Dangerous. But they are just Hot Rods for me. And Thanks for your ideas. Ron...
  20. ago
    ago
    from pgh. pa.
    nice interior.
    Ron Funkhouser likes this.
