Technical Summit racing power steering pump rotation
Discussion in 'The Hokey Ass Message Board' started by fatabone, Sep 25, 2015.
  1. fatabone
    fatabone
    I have a Summit Racing power steering pump GM type 2 style and want to know if anyone knows which way this should rotate. SUM-340106P_xl.jpg
  2. mgtstumpy
    mgtstumpy
    I believe that there are two (2) types, standard rotation and reverse rotation with OEM or remote reservoir tank. Some reverse rotation pumps have a 'R' or 'reverse' stamped on the bottom of the pump or side. Corvette pumps are high pressure & volume (3gpm) compared to other type II pumps (2.2gpm). I've got a reverse flow Corvette but want to run a 'V' belt, not serpentine system and need to locate another pump.
  3. gimpyshotrods
    gimpyshotrods
    Race pumps of this type, unless specifically labeled otherwise, are standard rotation.
  4. King ford
    King ford
    from 08302
    Standard rotation is clockwise from the front if that is what your asking.....
  5. fatabone
    fatabone
    Thanks guys it is standard rotation we have it working.
