Technical Sun Super Tach goes to 2500 max
Discussion in 'The Hokey Ass Message Board' started by 57chevymadman, Apr 13, 2025.
  1. I have a Sun Super Tach, worked great until today, now it only goes to 2500 rpm's max, any ideas?
  2. Mr48chev
    Is it set on the right number of cylinders for your engine?
    Just Gary likes this.
  3. Its a fixed 8 cyl tach (no switch), worked perfect for a year.
  4. 57Fury440
    57Fury440
    Did you check all the wires? Maybe a bad ground.
    deathrowdave likes this.
  5. deathrowdave
    deathrowdave
    from NKy
    Sounds to me also more than likely a weak ground .
  6. 1971BB427
    1971BB427
    from Oregon
    What ignition system is it hooked to? Points, electronic? What coil?
  7. Always check the easiest thing first. I agree with the suggestions that it's a weak ground........
    or a break in the wire inside the insulation. Probably somebody's size 12 shoe stressing the wire under the dash or a pedal mashed it enough times. The tach has probably been around the block a few times and wire(s) may have been spliced, including inside the pot.
    You could check the wire with a meter or just go straight to fabbing a new wire.
  8. flynbrian48
    flynbrian48
    Maybe it's the engine...;)
