Technical Sun Tach Experts ???
Discussion in 'The Hokey Ass Message Board' started by BigRRR, Nov 8, 2025.
  1. BigRRR
    BigRRR
    I have this vintage Sun Tach that I would like to convert from a 6cyl to 8 cyl.
    First question, does this tach require a transmitter box? looks to me like it wires directly to coil negative like all modern tachs, but want to make sure!
    Second, I read somewhere that adding a 15,000 ohm / 1/2 watt resistor on the sensing wire ( I ***ume coil - ) is all that’s needed to convert 6 to 8 cyl. Does this sound right - is it that easy?
    Thanks Ron
  2. BigRRR
    BigRRR
    Actually on closer inspection of the tag I am seeing that tach is for 2 cycles …. I’m now thinking this one will be a wall hanger :/
  3. pprather
    pprather
    I'm not familiar with any 2 cycle engines with 6 cylinders???
  4. Hollywood-East
    Hollywood-East
    Im going with marine..
    winduptoy and Sharpone like this.
  5. BJR
    BJR
    So if it was a 4 cylinder 2 cycle tac, would it work on a 4 cycle 8 cylinder engine? Or is my thinking totally wrong or backwards?
  6. Troublemaker427
    Troublemaker427
    Send it to Williamson Instruments in Arkansas. He will fix you right up.
    Todd553 likes this.
  7. winduptoy
    winduptoy
    I'm thinking that it may not be marine as the rpm range is so wide...and marine application is low rpm compared to automotive....
    cool tach and good luck
  8. RICH B
    RICH B
    I know it's no help; but the only 6 cylinder/2 cycle engines that I have dealt with didn't have distributors. They did have blowers, tho.
    427 sleeper and 38Chevy454 like this.
  9. jaracer
    jaracer
    Think Detroit Diesel, but at 8000 rpm that isn't a diesel tach.
    Hollywood-East likes this.
  10. 1934coupe
    1934coupe
    Unlike what his name implies, Troublemaker is right on the money. Williamson did 4 of my tachs and each one came out perfect.
    Pat
    Todd553 likes this.
  11. BigRRR
    BigRRR
    Thank you gentlemen for your insights. Looks like a total rebuild is the cure. Its a cool looking tach and will check out Williamson when I have decide to get it rebuilt.
    Pat out of curiosity, what was the ballpark cost when they did your tachs.
    Thanks,
    Ron
  12. 1934coupe
    1934coupe
    I'd be lying if I told you as it was many years ago I do remember it was worth the price. They did several different jobs, one was a 10G to 8.5G conversion. Another from Battery to transistors.
    Pat
