Sun tach SST-70 question...
Discussion in 'The Hokey Ass Message Board' started by Ledfut, Jun 9, 2007.
  1. Ledfut
    Ledfut
    A guy I know has a Sun SST-70 Tach he says I might be able to use. He doesn't know whether or not it is for a 6-cyl or 8-cyl. All he knows is that label on the back indicates that it uses an EB-7 transmitter. Does this help? Will this tach work with my V-8, or is it a 6-cyl tach?
  2. Fast67VelleN2O
    Fast67VelleN2O
  3. BigJim394
    BigJim394
    The SST-70 was a 7,000 RPM Tach. It could be used with 4,6, or 8 cylinder engines.
    If you wanted to use it in a 6 cylinder 12 Volt car, you would need to use the EB7A transmitter. If you wanted to use it in a 6 cyliner 6 Volt car, you would need to use the EB2A transmitter.
