Art & Inspiration Sunday Models 10-10-10
Discussion in 'The Hokey Ass Message Board' started by Zed, Oct 10, 2010.
  1. Zed
    Zed
    from FRANCE
  2. Stick Shift
    Stick Shift
    from LENA IL
    Yea! That is nice. KOOL!
  3. Murphy32
    Murphy32
    from Minnesota
    Great work as always Zed...the chrome tape on the roof seals the deal !
  4. LeadSledMerc
    LeadSledMerc
    WOW!!!...that's awesome, Zed!
  5. oldnuts
    oldnuts
    from nebraska
    your work is amazing.
  6. Royalshifter
    Royalshifter
    Moderator
    Wow again just amazing....you sure know your panels.
  7. Silhouettes 57
    Silhouettes 57
    Zed "hope you guys like it" how can we NOT LIKE IT? That thing is sooooo sharp!
    Thanks for showing it to us.
  8. hemifarris
    hemifarris
    Excellent workmanship.......
  9. TxRat
    TxRat
    Zed. Really nice work, paint is beautiful..
    Heres my contribution for this week. The surfers dragster.
    heres what I have so far.
    the ch***is is 157" which is what Tom has told me the length. Built from evergreen rod and tubing...
    Built the body, fuel tank and seat pan out sheet styrene added a few more tubes to the ch***is and wound up using the cowl from a old cobbled garlits FE rail. Building the frontend and wheels next.
    Thanks for looking
    here's the fuel injectors, pump and fuel blocks.
    heres the motor mocked up
  10. Rikster
    Rikster
    Looks fantastic Zed..... please make sure you get at least some photos of the car when your customer has it finished....
  11. Jarzenhotrods
    Jarzenhotrods
    from .......
    Zed that looks really really good!
  12. Zed
    Zed
    from FRANCE
    Thanks a lot guys ! Glad ya like it ! :D
  13. scrubba
    scrubba
    I wish Larry Watson and larry alaxander were here to see the great job ya did on the Thunderbird ! scrubba
  14. ClearSpot
    ClearSpot
    from Michigan
    Another stunner from Zed!
  15. Damn Zed, you are the paint master! Once again you're work just blows me away, now tell us the truth.
    Are you channeling the great painters??
    TxRat, that is looking nice! Can I ask what scale it it? Building tube ch***is is part of a build I think I enjoy the most.
    Once again, and as usual nothing from me this week. May have something for next week though.....................I hope.................
    Doc.
  16. TxRat
    TxRat
    its 25th scale Doc...
  17. Thanks man, I used to work in plastruct but I find br*** easier, give it a try!!
    Here is a half built ch***is next to a Tony Nancy car without the body (1/25th).
    Doc.
  18. Danburnsart
    Danburnsart
    from 59044
    Nice stuff...I just finished a 27 T roadster rod, but no photos yet...working on a 32 dry lakes racer, and a 32 sedan rat. Should be fun stuff!!
  19. billys54
    billys54
  20. sobpunx
    sobpunx
    man that bird has amazing paint!
  21. Bein55
    Bein55
    from Geneseo,IL
    That T-Bird is way cool. Got to get that guy in KKIM!
    Bruce
  22. Zed
    Zed
    from FRANCE
    thanks again guys ! :D
    i use cheap stuff i bought from Jammydog on ebay uk ;)
  23. Splinter
    Splinter
    On of these days I'll have enough cojones to post what I've been building..until then I'll just watch. DocWatson is the MAN!
  24. TxRat
    TxRat
    Doc,
    Thanks. I built front axles and other parts from br*** quite often.Yours looks great
  25. Jeez Splinter, I dunno' about that but thanks!
    TxRat, thanks. Don't get me wrong your ch***is is great. It was just an 'evolution' going to br***, also makes it a HELL of a lot less fragile!!
    Check this out in 1/32 scale, its less than 4 1/2 inches long!
    Doc.
  26. Splinter
    Splinter
    You should show the solder flux jar instead of the enamel jar-that's the only way I know of to get solder to flow that well!!! (P.S.-I'm going br*** tube shopping tomorrow. Thanks for the tip!)
  27. No worries, yeah I use a liquid flux for the solder. All my tube is cut with a Dremel and a cut off wheel, its easy to then notch the tube with it as well. I also use some of those small needle files for fine fitting the tube, the better the fit the easier it is!
    I tried using a 'Third hand' for a soldering jig but they are no good, I use everything from small 'Cleco' paper clamps, blue tack (Only if that area isn't getting hot!!) squares of steel, anything!!
    My soldering iron is a cheapy 40watt from **** Smith, I like to use non rosin core solder as the rosin is a ***** to clean off latter. Normal soldering prep, ie; clean, tin then solder.
    I want to try one of those butane torches but a decent one is expensive and is out of the budget.
    The br*** I use is K&S and Albion Alloys, both from the local hobby shop. Get ready for a shock in the price though!!
    One of the best things I ever invested in, is a large cut off of hardened gl*** to use as a work surface, grantees everything is level, cleans off easy and you wont leave gouges in it like most other surfaces. It also wont burn like my laminated work bench did when I first tried to do this!!
    Splinter, please post up some of your work, I bet its better than you think!
    Doc.
  28. Dr.Kerry
    Dr.Kerry
    Hey Bruce I agree. I think he joined the forum not to long ago!!!!!! Great stuff ZED!!!!!
    Here's mine, haven't been on here in awhile.
    51 Bel Air, chopped 50 Ford roof, sectioned rear fenders, Pancaked hood with Chevy lower hood section and 50 Ford top hood section.
  29. Deuces
    Deuces
    Wow, no "click on" pictures this p***ed week??? What a shame.... :(
