Sunday models
Discussion in 'The Antiquated' started by milo1303s, Mar 16, 2014.
  1. Deuces
    Deuces
  2. Deuces
    Deuces
  3. Deuces
    Deuces
  4. The 62 409 is Killer!
    Deuces likes this.
  5. Deuces
    Deuces
    Yep! Love that cowl mounted cold air cleaner....;)
    mchook and Sancho like this.
  6. Deuces likes this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    @Deuces , the same rules apply here as on the main board. The cut off is 1965 and NO MUSTANGS
    Dan Hay likes this.
  8. Resin Altered Wheelbase 65 Chevelle on a shortened Revell frame and a Chrysler 440 and velocity stacks just to be different! IMG_20230406_120258947.jpg IMG_20230406_142640796.jpg
  9. I got the engine mounted up ,in order to make it fit I had to remove the oil pan and replace it with a shallower unit in the reversed position IMG_20230407_140753718.jpg IMG_20230407_140842478.jpg
    dehartcarl, mchook, Sancho and 3 others like this.
  10. Made the roll bar ,took awhile to get the height correct. IMG_20230407_222909570.jpg
  11. 41 coupe
    41 coupe
    from bristol pa
  12. junkyardjeff
    junkyardjeff
    Making a larger truck out of a Monogram 40 Ford pickup,using mostly left over parts on this build. Engine is from a AMT 57 T bird and the two speed rear axle is from a Lindberg Dodge cabover. IMG_20230409_115009457.jpg
  13. Installed the gl*** and dash board .Just for fun I sprayed the gl*** with transparent red. IMG_20230410_131057409.jpg IMG_20230410_173443567.jpg IMG_20230410_173505459.jpg
  14. Took it outside for some photos. IMG_20230411_090053593.jpg IMG_20230411_090119749_HDR.jpg IMG_20230411_090139387_HDR.jpg
    mchook, NHRANUT, simplestone and 3 others like this.
  15. Dan Hay
    Dan Hay
  16. The 39 guy
    The 39 guy
    Your Tub came out great Dan! I'll have to look up your U tube Channel.
    Dan Hay likes this.
  17. rc57
    rc57
    Wow! That turned out beautiful.
  18. junkyardjeff
    junkyardjeff
    I have one of the original AMT version I need to restore.
  19. Didn't that come with a trailer and tow vehicle?
  20. junkyardjeff
    junkyardjeff
    I think it did but I got mine back in 74 out of a car in a junkyard with other models and parts.
  21. junkyardjeff
    junkyardjeff
    Doing a ch***is rebuild on the 40 built in the 70s,all the bumper brackets were broken off and I plan on using the custom bumpers. Adding the 390 from the 34 pickup kit. IMG_20230416_165411529.jpg
  22. 41 coupe
    41 coupe
    from bristol pa
  23. Dan Hay
    Dan Hay
  24. rc57
    rc57
    Quick polish and a little detail. I had gotten a "fixer upper" Willys last year, and the more I take it apart it the more it seems like somebody's dog built it. I have my work cut out.
    Dan Hay likes this.
  25. greaser 35
    greaser 35
    from FRANCE
  26. Dan Hay
    Dan Hay
