Sunday models
Discussion in 'The Antiquated' started by milo1303s, Mar 16, 2014.
  1. Moonglow
    Moonglow
    Apparently I've been out of the email notification loop for a while. Nice work fellers!
    I had a couple spare hours this morning, so I made a build board for project "Big Tuna". The bottom body shell half is on wood blocks that represent about 3 scale inches of ground clearance.
    Now that I see the relation of body shell to the tires I think the tires need to be taller and thinner at the tread. This inspiration photo seems to bear that out.
    As they are now, they scale out to about 28" tall x 4.5" wide, at the tread. By adding 1/4" black foam around the perimeter, I'd end up with scale dimensions of about 30 -1/2" tall x 4" wide at the tread. I'm leaning in that direction...
    Cheers!
    PS: The flange around the drop tank's perimeter will eventually be trimmed back quite a bit.
  2. Moonglow
    Moonglow
    @Lucius Molchany , I have no idea what those wheels are on this belly tank. It's just visual guesswork on my part as to what looks right.
  3. Very cool ,perhaps paint it white with red scallops!
  4. Moonglow
    Moonglow
    Hey @Lucius Molchany ,
    I'm definitely leaning towards red scallops, but weathered and beat up a bit. Not likely over white, but instead over what I hope appears to be oxidized and banged up raw aluminum, kinda like this...
    The idea is that it's to be a low budget garage build from the late 50's. No sponsor, little money, just good-ole post war American know-how. I'm not going for a pretty So-Cal Speed Shop look, but instead, a one-off down & dirty (and pretty greasy) drop tank salt flat racer with an early Hemi (and a quick change rear-end) instead of the more conventional Ford flathead V8 (and Model A banjo rear-end).
    Talk about being a rebel without a cause... Ha!
  5. With a Hemi and it's light weight it should scream,!
  6. Moonglow
    Moonglow
    Apparently there weren't many belly tanks with Hemi engines, but one was summarized as follows:
    "The tank, nicknamed "Salty Shaker," held many SCTA speed records over the years. Frye drove his way into the Bonneville 200 MPH Club in 1957 with a speed of 216.750, which was updated to 240.650 by the time he stopped racing it in 1963."
    Here's a link to the full story:
    http://www.thehemi.com/forums/viewtopic.php?t=5735
    Accordingly a stock Hemi had some disadvantages over the ole reliable Ford V8 flatheads of the day perhaps because the advantage of wide range of speed equipment readily available for it. Much less so for an early Hemi.
    Still, it's hard to deny the cool factor of a Hemi in a P-38 Belly Tank.
    I can't afford the real deal, but I can build a 1/5 scale one.
  7. Deuces
    Deuces
    Found these on the net.... 1932_Ford_V8_Sedan_Delivery-fvla.jpg 1928_Ford_Model_A_Panel_Delivery-fvl.jpg 1923_Ford_Model_T_Delivery_Van_Olympic_Laundry-fvr.jpg 1916_Ford_Model_T_Delivery-fvr1.jpg 1941_Plymouth_Special_DeLuxe_Coupe-uvl.jpg 1941_Plymouth_Special_DeLuxe_Coupe-rvl.jpg 1941_Plymouth_Special_DeLuxe_Coupe-fvr.jpg
  8. 1/24 Monogram Metal MG-TC kit IMG_20241119_112808319_HDR.jpg IMG_20241119_152831347_HDR.jpg IMG_20241119_152854617_HDR.jpg IMG_20241119_152906884_HDR.jpg
  9. junkyardjeff
    junkyardjeff
    Picked this one up built, someone took the 60s body and put it on the 70s version ch***is so I fixed it. IMG_20241129_154508957.jpg IMG_20241208_133009649.jpg IMG_20241208_132857639.jpg
  10. sweetdick2
    sweetdick2
    from new jersey
  11. sweetdick2
    sweetdick2
    from new jersey
    A LOT of talented builders out there!!
    65pacecar and Deuces like this.
  12. Deuces
    Deuces
    Found a few more.... 20241208_183534.thumb.jpg.926d67d1b2c3b1a3380b7a24b1a42a1d.jpg 20241208_183521.thumb.jpg.1cd8458e67e43ba0a3e5b72afaf9caf8.jpg 20241208_183515.thumb.jpg.643e5a7c498a2645b5d1593ffd6c8440.jpg 20241208_183503.thumb.jpg.62392848033b32de6c3b239c9bb9505b.jpg 20241208_183446.thumb.jpg.fa0fab0a55e3109d997f65ee167f1bba.jpg 20241208_183436.thumb.jpg.334d72b71cd46912e65a034c1ce0ca2d.jpg 20241208_183421.thumb.jpg.6e1ee0ed27987f079e624f4c57acc7be.jpg 20241208_183409.thumb.jpg.4540b08464d92dc6e56d379f0fb0b6b8.jpg 20241214_111713.thumb.jpg.e426cdb9464797355e104998508b0176.jpg 20241214_111743.thumb.jpg.d64f23c26e6120957e69e438baf20237.jpg 20241214_111834.thumb.jpg.5bff0be1069705c7cf58836c13a5c49c.jpg 20241214_111752.thumb.jpg.662358d318e73b200fefb2bbdc983cce.jpg 20241214_111855.thumb.jpg.c6a2fd2b284e966fc042511544354559.jpg
  13. NHRANUT
    NHRANUT
    from Western PA
    My latest build.
  14. edcodesign
    edcodesign
    Church Key, 54delray, Deuces and 5 others like this.
  15. dehartcarl
    dehartcarl
    Deuces likes this.
  16. dehartcarl
    dehartcarl
    Super nice build!
    Deuces likes this.
  17. Deuces
    Deuces
    Here's a few more.... 7IMG_4800.thumb.JPG.91ee4a97068f26fddca7a0caa41ad70c.jpeg 8IMG_4801.thumb.JPG.cbff6dccbc8611010354c4bca73c4cb8.jpeg IMG_4822.JPG.3d2a7933b5ffb5481fa4388ab5aba0a9.jpeg IMG_4818.JPG.8739b3bdfba2fb40ff1ff8ebd56146bc.jpeg IMG_4820.JPG.cdff63cdd9abe7dbb1cbea81a129cfc5.jpeg IMG_3363.thumb.JPG.4fd82099d002c19cb351293279ef7f94.jpeg IMG_3362.thumb.JPG.ad081a8c686e3754c15abce3d8c365e0.jpeg IMG_3360.thumb.JPG.0e3c10b16f0e1f27d043da9ab4b476a3.jpeg IMG_3359.thumb.JPG.eb7c1675fa9fa787970b87652ab234aa.jpeg IMG_3361.thumb.JPG.335946a9d3d447a5ffb40c1146524768.jpeg IMG_20241208_101934.thumb.jpg.fe9e0fc09007bf843dcba17c9a92b4c3.jpg IMG_20241208_101910.thumb.jpg.990d6243e88d43c41b623735fe84a17b.jpg IMG_20241208_101837.thumb.jpg.8f223694d4017b90f96430344f82ece5.jpg IMG_20241208_101827.thumb.jpg.bc63320594300babe01028e8c8035cc8.jpg IMG_20241208_101810.thumb.jpg.4e3efb56066053feee2f0a677797edac.jpg IMG_20241208_101802.thumb.jpg.6e3b080bb2fd48f6f1dfc915e4b746a6.jpg IMG_20241208_101752.thumb.jpg.40a12e27bd4bc42dbe53b4a7f283b2bc.jpg IMG_20241208_101743.thumb.jpg.85c9dfe960a2fece2fa7f1786c7b3807.jpg chevy1966grayongray07.thumb.jpg.a3efeb59ce1f5583e0e0751da807efb5.jpg chevy1966grayongray06.jpg.f48450195f98c4c9c1c34249930bd022.jpg chevy1966grayongray05.jpg.e5a2e0129e3191f48bfe4bc89bcc1921.jpg chevy1966grayongray04.thumb.jpg.9967deff3429601ae6e76f3e33b0afe2.jpg chevy1966grayongray03.jpg.016fdca63f167fb8cf91d56288683af9.jpg chevy1966grayongray02.jpg.8cf009be14a760d1bf973316d4be2ddc.jpg chevy1966grayongray01.jpg.b3b969c2aa8d507c6e7a0655d11dc187.jpg IMG_8913.thumb.jpeg.9cf1244d576273769c2fd4f2b2035f7c.jpeg IMG_8912.jpeg.aef03d8c462c4cfaa0a0d6dcf15bf391.jpeg IMG_8904.jpeg.ba1e80f68b6f8ab8313150c26c6c3d9b.jpeg IMG_8905.thumb.jpeg.ec2bd7f0df0ecb35d38b36cb4b63458f.jpeg
  18. junkyardjeff
    junkyardjeff
    Found almost enough parts for a AMT 40 Ford,fenders are from a sedan so it's going to be a standard coupe with a 430 MEL from one of the 60s hotrod T kits. IMG_20241220_164645084.jpg IMG_20241220_181527724.jpg
  19. Bigcheese327
    Bigcheese327
    Hey modelers! It's been a long time since I've made a serious attempt at finishing a model, but for Christmas, I was gifted an AMT 1961 Ford Galaxie Club Victoria. My 12-year-old daughter has been picking away at a mild-custom version of the AMT 1953 Studebaker Starlight for a long time and seeing me acquire a model got her fired up to complete it to display alongside the Galaxie.
    Poking around on Scalemates, I discovered this period-style gas station called Joe's Power Plus Service. Has anyone built it? I'm wondering if it's doable for a rusty amateur and a young beginner.
    Thanks!
    55 Ford Gasser, 54delray and Deuces like this.
  20. s.e.charles
    s.e.charles
    it's styrene; how could it be messed up beyond repair?
    now, a Revell '56 Ford pickup is another conversation entirely ....
    '56 Ford Pickup, Revell H-1283 (1963)
    show me a 14 year old who could get this together and i'll show you the next Bill Hines
    54delray likes this.
  21. edcodesign
    edcodesign
  22. junkyardjeff
    junkyardjeff
    Rebuilding this older 40 Ford . IMG_20241220_164645084.jpg IMG_20241227_153232754.jpg
  23. Deuces
    Deuces
    Check out Grandpa Mark's hobbies on you tube... I think he has one of those he's working on....;)
    Bigcheese327, HJmaniac and 54delray like this.
