Sunday whacha get done? post
Discussion in 'The Hokey Ass Message Board' started by Paul, Mar 21, 2004.
  1. Paul
    Paul
    Editor
    (as already seen in another post)
    I primered the doors yesterday,
  2. Paul
    Paul
    Editor
    and today I started swappin out the Man-A-Fre for the 2x4 X-Ram
    what did you do?
  3. kustumizer
    kustumizer
    from Alton,NH
    got my hood in color and finshed up the******* in the comet!! I like your new intake 60s style!! Nate
  4. I finally have something! I got my frame from kartbreaker, and brought it home. Now it's onto boxing and making mounts for the stovebolt... [​IMG]
    Jay
  5. forsakenfew
    forsakenfew
    from seattle
    i managed to stop my stereo from shutting off everytime i hit the brakes!! not a huge deal, but man was that*****ing annoying. (did you know that the block needs to be grounded to the frame?? [​IMG])
  6. sawzall
    sawzall
  7. Fixed my stupid windscreen wipers....traced faulty indicator to back under dash and then had no feakin idea..oh well try next weekend.
    Hung out with Pscyobilly Boi, lowsquire, and met adam f.
    Fun drinking.
    Cheers
    Maiki
  8. Jkustom
    Jkustom
    worked most the day, then tought my sister about engines.... what everything does, why it does it...... how to read plugs and "sorta-tune" a carb..... Tought her why my nailhead smokes these days...... Now she wants to learn to weld....... -J.
  9. Paul
    Paul
    Editor
    [ QUOTE ]
    [/ QUOTE ]
    Hey Justin, you get that welder goin yet?
    Paul
  10. Bob K
    Bob K
    from Antigo Wi.
    Relearnt something I shoulda remembered from many years ago.
    Don't install your side trim on the doors if you don't have the door checks installed. Now I've got a nice dent in the stainless that I have to take out.
    Damm what a*****y move.
    B [​IMG] B
  11. FORDY 6
    FORDY 6
    Got the dropped axle/spring/spindles together for my '31.
  12. poncho
    poncho
    with some help i changed my brake cylinders,shoes,master cylinder,some hard lines and the front flex hoses...and cleaned out my shed..to much junk!!!chilled out most of sunday[today] [​IMG]
  13. zman
    zman
    from Garner, NC
    Sanded and primed the new bed for the '59. Worked on the crossmember for the Buick/Jag suspension swap.
  14. Levis Classic
    Levis Classic
    Fab'd some patches for my vintage recessed firewall. ALso strarted fabing my toe boards for teh 29 TUDOR.
  15. Rocket88
    Rocket88
    Turned 40, had a big party, got drunk!
    Nursed a hang over today. [​IMG]
  16. Grumpy
    Grumpy
    from NE Ohio
    1st- got all pinstriping done on flames, tailgate and dash of the truck.
    2nd-got the www mounted/bal. and put on truck. now on it's own feet.
    3rd- got oak cut for bed floor, wife poly'd it 3 coats, going in tomorrow.
    4th-sold my soul and gave up lots of stuff for a set of 54-55 olds flipper caps for the truck.
    ahhh, now I'm tired............
  17. Zeke
    Zeke
    With a lil help I got this done. [​IMG]
    LOTS OF HELP!! [​IMG]
    HAMB GAS RULED!!
  18. Ham
    Ham
    Actually feel like I made some progress today. Got the rear suspension dialed in, new 4" drop leaf spring, etc. That's about it, then it was dad duty with the new little hot rodder! [​IMG]
  19. Got most of the old paint DA'ed off the 54 Chevy. Then shaved and primered the passenger door. Pulled more trim, and drank more beer.
    Geno
  20. I got the whole air conditioning setup put in her majesty's commuter. (A little OT)...Converted it to 134A and it works!!
    It at least quits the******ing on that subject...now for the rest of the Honey-do list........
  21. ABone312
    ABone312
    I finally got the body painted satin black to match the rest of the car on the '31 coupe. Then I layed out the scallops and sprayed them. I also started mounting the new seat. I'll finish it tommorrow night, then I can take it easy till the Round Up this coming weekend.
  22. DrJ
    DrJ
    I waxed the blue truck before going to the HAMB BBQ/picnic
    Made some contour templates off the 60'Elky's right fender wheel opening flare so I could check the same on the left fender that I'm fixing tears and straightening from a thrown tread off a steel belted radial's damage.
    I made three plaster patches on the fender and removed them and cut theplaster patces up the middle on the band saw then traced the contour on a sheet of phenolic (that red-brown board that is used to be used for electric circuit boards) with a sharp scribe and cut them out. Now I can check my progress metalworking the flare back into shape.
  23. Suede57
    Suede57
    sanding & stripping the 57 ready for paint
  24. Missing Link
    Missing Link
    Not much here...
    Picked up some more striping brushes and some more 1-shot, started on my contribution to the "wall o' stripes", finished up painting a magazine rack I had flying around for about seven years, started doing a mock up on a sign for Sawzall, tried to drop the car down off the stands but found out my floor jack is not working again...I hate that*****in' jack...put the heater box back in the ford after making some much needed alterations, put a clock in the dash, stopped to look at some old cars that the WIFE spotted. I still can't believe she saw them and then actually told me about it. And then added "we should turn around and go back to see what was there." Some good stuff but real rough...guess I did more than I thought this weekend. Hell, I even managed to make time to get loaded and watch some hockey. [​IMG]
  25. HAMB gassed big time. Wire wheeled, grinded, drew pretty chalk lines, wielded the cutting torch, grinded some more, ate fajitas, drank servezas, slept in a bunkie (thanks little rads! ), got majorly dirty and generally had a blast with my new buds.
    Then I drug everything that wasn't bolted down home from the New Mexico wilderness. Weathered lumber for my mom, driftwood for some landscaping and vintage tin for ME!
  26. flamedcoupe
    flamedcoupe
    Put the new dash in the 34 fordor that I'm working on for a friend. Thought I was going to have to modify my left hand to get one of the nuts on a stud. Sure was easier before the heater hoses and a/c were in the way. Hope to have this done soon so I can get back to work on the Cushman.
  27. dixiedog
    dixiedog
    I got to enjoy Daytona Spring Run and Swap Meet - it was really light crowd this year, pretty boring.
  28. Bugman
    Bugman
    Helped a buddy swap a cam and intake into his SBC.
  29. JimC
    JimC
    from W.C.,Mo.
    Went to a club meeting/dinner/auction.
    Scored a set of original baby moon caps in great condition, with a brushed beauty ring thrown in. I have no idea what I will do with it, maybe, hang it on the wall.
    Beat on the roof of the 47 for a while.
    Jim
  30. 30roadster
    30roadster
    I finished trimming the welting flange off of the gas tank (top) panel on the cowl of my 31 and welding the panel to the firewall. annoyed my neighbors with a die grinder [​IMG]
    and next weekend i'm going to the ROUNDUP! [​IMG]
