Technical Super Bell Axle Kingpin Bore Issue
Discussion in 'The Hokey Ass Message Board' started by 32SEDAN, Dec 14, 2025.
  1. 32SEDAN
    32SEDAN
    Finally received my chromed Super Bell Drilled I-Beam axle for my car 32 roadster project after months of waiting due to being backordered I noticed the kingpin bore on the drivers side is quite a bit off center compared to the p***enger side. See pictures.
    Outside of camber adjustment issues, I’m concerned that will be a weak spot in the axle. Is this misaligned off center bore issue common? Kind of disappointed as it was very expensive and I had to wait so long. I replaced a cheap I-Beam axle with this one.
    what do you think about it? I sent a note to Super Bell as well.
    First picture is the off center bore on the driver’s side and the next picture is the p***enger side.
  2. TCTND
    TCTND
    I would not accept that. Driver's side looks dangerously thin, p*** side pretty sloppy.
    Squablow, mad mikey, bobss396 and 4 others like this.
  3. pprather
    pprather
    I'd encourage you to call Jason at Pete & Jakes.
    TERPU, hrm2k, MMM1693 and 3 others like this.
  4. leon bee
    leon bee
    Stuff like that is over my head, but I wouldn't like that. Interested to see what they say.
    Makes a real case for taking stuff apart and inspecting right away.
    32SEDAN likes this.
  5. 32SEDAN
    32SEDAN
    I sent him a note. He’s been helpful before. Thanks
  6. Tim
    Tim
    from KCMO
    Since the obvious answers have already been added I do have a question. Is this axle for early ford spindles or something else?
    32SEDAN likes this.
  7. 32SEDAN
    32SEDAN
    Yes sir
    Tim likes this.
  8. JD Miller
    JD Miller
  9. 19Eddy30
    19Eddy30
    from VA
    Just curious Did it come from S-B directly, ?
    32SEDAN likes this.
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Hmm...interesting. Hope you can get it rectified.
    mad mikey and 32SEDAN like this.
  11. 32SEDAN
    32SEDAN
    It did
  12. Buckster
    Buckster
    I wonder how the king pin fits the axle being the offset bore ??
    32SEDAN likes this.
  13. 32SEDAN
    32SEDAN
    Me too!
  14. 32SEDAN
    32SEDAN
    Jason responded:
    I have seen this through the years. During the forging process and cooling, sometimes the axles will move (known as shift). This creates the centerline of the axle to change slightly, whether vertically or horizontally. The part is so long and gets so hot during the multiple strikes it takes to make the axle. It starts out as a 3” diameter solid bar, then the drop gets formed first with a forming die. Then shaped, lastly trimmed. Next step is machining…so when the axles are then put in the cnc for machining, the centerline is found within the forging. Which can create what appears to be an offset center. But yet the alignment of the axle is still true.
    Strength of the axle is not an issue at all….this is a US forging that is made in Ohio. Same company doing forgings on this axle since the early 80’s.
    Doing these axles for so many years, we design a “larger” than necessary end on the axle to allow for any forging shift. Although this is not very common, we still design them this way.
    Johnny99, Tim and 19Eddy30 like this.
  15. JD Miller
    JD Miller
    So its Mint !
    32SEDAN likes this.
  16. blue 49
    blue 49
    from Iowa
    I thought Super Bell axles were cast ductile iron. I've had a couple.
    Gary
    32SEDAN likes this.
  17. 32SEDAN
    32SEDAN
    Forged not cast
  18. 32SEDAN
    32SEDAN
    Right?!
    JD Miller likes this.
  19. 60 Special
    60 Special
    from Omaha Ne.
    Those pictures look like something that came out of China! IMO I wouldn't accept it! 60 Special
    32SEDAN and Fogger like this.
  20. SPEC
    SPEC
    You can trust what Jason tells you!!!
    bschwoeble, 32SEDAN and MMM1693 like this.
  21. NoelC
    NoelC
    I'd take it apart, find an open space, draw some reference lines, laid flat with some fitted dowling protruding compare notes on any deviations. I'm sure Jason is a nice guy like Nixon wasn't a crook. That's to suggest you spent good money and expected better, and the story doesn't excuse the quality you expectedly paid for.
    Right now all you have is, "I don't like it", and that apparently isn't good enough.
    Holes should be centered. Missed it by that much is what they did. Opps, that day Jimmy wore loafers instead of work boots to hold his end while it was being drilled in the press, missed it by that much?
    My stocker doesn't compare to chrome fancy...but the hole is where it's supposed to be. LIke buying a colt sired from the best stallion, only do find it's got one leg pointed funny. That's why I think it should be returned.
  22. Motorwrxs
    Motorwrxs
    Is it just me or does it look like it will position one wheel a little further in front on the other relative to the axle?
    32SEDAN likes this.
  23. Fogger
    Fogger
    Definitely a defective forging, return it for replacement. Don't accept the excuse you've been offered.
    32SEDAN, mad mikey, JD Miller and 3 others like this.
  24. alchemy
    alchemy
    Return for replacement or refund.
    32SEDAN and hrm2k like this.
  25. NJ Don
    NJ Don
    32SEDAN likes this.
  26. Fordors
    Fordors
    I think I have to side with @NoelC , I’d expect better. Think about how many early Ford beam axles were produced, has anyone ever seen one that bad?
  27. Bentrodder
    Bentrodder
    from Cotati
    I say send it back for a replacement. You said you spent good money for it and deserve for it to be to your satisfaction. The time spent waiting you'll never get back but always having the thought in your head knowing its not right would be worse.
    32SEDAN likes this.
  28. dirt car
    dirt car
    from nebraska
    Doesn't seem to be the quality expected of a top end product that is deserving of the expensive prep & chrome plating, it would seem the final shaping of the solid bar in its raw form at least on the end areas would be trimmed after the k.p. boring to ensure plenty of material totally surrounds the bore. I would surmise the best defense while difficult, is to visit the store & pick the axle of your choice or request photos of the critical areas & finish etc.
    32SEDAN likes this.
  29. RodStRace
    RodStRace
    This kind of thing was an issue with old BB mopar rods. The pin hole was not always perfectly centered in the center of the part. While I didn't see or hear of the pins pulling through it was sloppy m*** produced work.
    I understand the description (apology) of the process, and it may well be strong enough to run. However I feel this is a Quality ***urance fault in the manufacturing process. It would be a short, simple step to drop the unmachined axle into a jig that spots the kingpin locations. If they do not p*** this, either bend to align or move this to the 'blem' pile. Does every forged part come out good enough in every crucial dimension after cooling? Is there a straightening process already at this point in manufacture?
    Having it go through machining, polish and plating then sold as a premium product is sad. I bet they do not have a picture of this on the sales site and explain that you may receive one like this and 'it's no big deal'! I do expect to hand select 2x4 lumber at the local big box store. I do not expect (and I bet they don't allow) having to do this at a rod shop.
  30. TA DAD
    TA DAD
    from NC
    I bet the guy that sold it and says it ok would not accept it if it was his money on the counter.
