Hot Rods Supercharged 302 in Model A 1930
Discussion in 'The Hokey Ass Message Board' started by deskjet894, Feb 5, 2024.
  1. deskjet894
    deskjet894
    from ma
    I am building a 1930 Model A on a 1932 frame.
    The engine is a SBF 302.
    Will a Dyers supercharger fit?
    Can you slow the supercharger down for a stock engine?
    Deuces likes this.
  2. fastcar1953
    fastcar1953
    yes and yes
    Deuces likes this.
  3. 270ci
    270ci
    Superchargers always fit! Sometimes you have to cut a hole in the hood, but it will fit!
    -Brent-, Deuces, WC145 and 2 others like this.
  4. Unkl Ian
    Unkl Ian
    Friend of mine had a SBF in a Model A, with a stock style frame.
    The SBF is long enough, the firewall needed to be cut.
    Later, Ford came out with a shorter water pump, which would have helped.
    Can you get a blower manifold for a SBF ?
  5. miker98038
    miker98038
    There’s lots of different “stock” SBF’s. You’ll need to know the “real” compression ratio, hopefully both the static and the dynamic (based on the cam). Be conservative going in.
    I’ve run McCulloch’s on stock and modified yblocks, and Roots style on OT motors. Great fun, but be careful not to overdo it. It’ll probably be detonation that’s the real enemy if you do, and that’ll kill any engine pretty fast.
    Deuces likes this.
  6. oldiron 440
    oldiron 440
    Most 302s have between 9 and 8 to 1 compression ratio and can handle five pounds of boost with stock iron heads. If you can find a good one look for a 5.0 from a late 90s mustang or fox body Lincoln they have better rods and forged pistons then add aluminum heads and go for the gusto. These stock short blocks have run in the eights in the quarter.
    Deuces and gimpyshotrods like this.
  7. Deuces
    Deuces
    Yep! Stock fox body 5.0s have TRW forged pistons.. 1988-91..
  8. deskjet894
    deskjet894
    from ma
    Yes they made a blower manifold for a SBF
    Deuces likes this.
  9. Jalopy Joker
    Jalopy Joker
    so why wanting to run a blower? just to look tough or ?
  10. deathrowdave
    deathrowdave
    from NKy
    I have roller 5.0 in my 32 . X grind cam , roller rockers , roller fuel pump eccentric , Keith Black pistons , GT 40 heads , it will rev like a Stihl Chainsaw . Only issue is the length of the overall engine , requires some crafty thinking .
    Unkl Ian likes this.
  11. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
