Projects Supercharged 55 Thunderbird project
Discussion in 'Traditional Hot Rods' started by hotrod--willys, Sep 21, 2018.
  1. hotrod--willys
    hotrod--willys
    This is my new project. An all original 1955 T bird. Original 292 Y block. My goal is to restore the exterior total stock. The same for the interior. 292 bored to 305". Original Jahns Pistons. Mild Isky cam. I'm going with a VS57A Supercharger. This will be a fun project.
  2. dana barlow
    dana barlow
    from Miami Fla.
    Love Bird's 55,56,57,wish I'd had one. But my hotrod 28 "A" bobtail roadster has been powered by a Y-block Ford Thunder bird from the time I built it for high school in 1959 an still is !.
    Y-292 can not be bored out to 312 per say.
    Ford got up too 312 by putting in a bigger crankshift with more stroke/an some bore ,but also made bigger main bearings =can't just add 312 crank to 292 block. You can how ever under cut 312 crank mains to fit 292 or just get a Ford 312 motor to start with. Adding a supercharger can only be done if cly psi stays low,around 8 to 1 or less/do some reading about supercharging. Handy site ; http://www.ford-y-block.com/
  3. hotrod--willys
    hotrod--willys
    I Just discovered that I have two different lower A arms. I'm not sure which one is the original. The looks show that the drivers side is the original. I need a lower p***enger A arm for a 1955 Ford p***enger car or Thunderbird. The drawing shows the distance from the frame mounting ends. It needs to be 18&5/8 from lip to lip. IMG_1332.JPG lip as shown. Any one that can help me with this would be appreciated.
  4. hotrod--willys
    hotrod--willys
    I'm on my way taking the Bird apart. Nice original California car. No rust at all. I'm not doing a frame off. I will steam clean the under carriage and engine compartment. Sand blast the front suspension. Disc brakes up front. [​IMG]
  5. hotrod--willys
    hotrod--willys
    Thank to the guys in the Pacific NW for the help with my A arm problem. Have my NOS lower A arm[emoji106]
  6. 6sally6
    6sally6
    Love the "early birds"!
    Friend of mine had a 55 her Dad totally restored. (A N.M. car) Sweeet ride. One thing....unless you are a skinny/puny guy...you gonna hafta do something about that 55 steering wheel. It is HUGE! PS and a smaller wheel if you're gonna leave the interior original. A great look'in little car.
    My first car was a 54 Ford Crestline with a 312 swapped in it. 3-on-the-tree! It would bark'em in 2nd gear...no problem!
    Have fun
    6sally6
  7. miker98038
    miker98038
    Don’t want to hijack your thread, but if I can be of any help pm me. I’m in Kent,WA.
    kidcampbell71, mgtstumpy and loudbang like this.
  8. Malcolm
    Malcolm
    from Nebraska
    Very cool project! What transmission are you going to run? A 5-speed sure would be fun..
  9. jimmy six
    jimmy six
    Good luck. Going to be a fun project to watch. There are a lot of parts for the early birds.... Is that a swamp cooler under the dash?
  10. hotrod--willys
    hotrod--willys
    I
    The car came out of California. It is after market air conditioning. Called FrigiKing
  11. hotrod--willys
    hotrod--willys
    kidcampbell71 and loudbang like this.
  12. hotrod--willys
    hotrod--willys
  13. hotrod--willys
    hotrod--willys
    Here are some pic's of the engine done. I'm looking for a 1957 T Bird distributer. Also I need a divers side front half air duct. Something bad happened to mine as you can see.
  14. loudbang
    Looks GREAT!!!
    kidcampbell71 likes this.
