Technical Supercharging a Flathead V8
Discussion in 'The Hokey Ass Message Board' started by TheSteamDoc, Jan 24, 2020.
  1. TheSteamDoc
    TheSteamDoc
    Was wondering if the 4-71 super charger with dual Stromberg 97's on a Flathead Ford V8 is worth the expense? Who sales a good qaulity set up that's era correct with V belts? Looking for a early 50's style set up. What can of power and torque increase can I expect? I'm thinking 225 HP Max. I don't expect over 250 HP.
  2. v8flat44
    v8flat44
    There is a thread on here about an A V8 roadster build & it looks like a 4-71. Search it ??
    What's the engine going in? You may wanna post on The Ford Barn too.
    What is the loco in your avatar..?..i love Pennsy K-4 & 5s , Y-6-bs to name a few.
  3. Bandit Billy
    Bandit Billy
    I did it. I suggest buying Joe Abbins book on the subject and follow it letter for letter. Build the bottom end as well as possible, don't over boost it, 8 pounds is plenty. I did a ton of porting, CNC main caps, Navarro blower heads, 8:1 compression, .125 over ross pistons on a merc crank.
    Center 97 until half throttle then you get the other two and you need to be paying attention at that point. Worth the money? Hell yes!!
    GordonC, Jet96, loudbang and 2 others like this.
  4. TheSteamDoc
    TheSteamDoc
    '32 5 Window Ford someday. The engine in my avatar is a FEC Rwy 2-8-2.
    stillrunners likes this.
  5. krylon32
    krylon32
    from Nebraska
    I did a fairly standard FH build for my 32 roadster and added a Road Runner Engineering blower setup running 5 lbs of boost and it really woke up the motor. It wasn't as impressive as the 471 but I liked it for it's compactness.
  6. old school rodder
    old school rodder
    I bought Joe's book, then met up with him and chatted blown flatheads. His book has some very interesting data in it and theories, which I think are spot on. The 4-71 displacement can overwhelm a 270 cu.in. flathead. I suggest finding that book, then go from there. I developed a Weiand based blower setup from parts available almost anywhere, H&H has a 4-71 setup, Tom Roberts has a magnusen setup. Most will claim a blown flathead will probably top out around 250 hp unless you get very exotic. It's a fun challenge getting a blower on these things, lots of little details.
  7. choppedtudor
    choppedtudor
    I put this together and it's a handful...a 471 on a Mitchell intake, running 8 lbs of boost with a 4:11 rear and skinny tires...oh, and the low first gear in the 700r4 helps a bit too...lol
  8. Mike VV
    Mike VV
    from SoCal
    H&H FlatHeads in SoCal has all the goodies for that installation.
    Was looking at it at the Roadster Show today.
    Mike
  9. stillrunners
    stillrunners
    from dallas
    Aren't our Aussie friends down under working/selling a new set up or just a manifold ?
  10. fullhouse296
    fullhouse296
    from Australia
    On a stockish engine ,a 4/71 is too much drag to turn over . Sure , it will look good and it will run . But , this is what you will find . It will be sluggish and boggy till round 3k it will pick up after that . and thats with a stock 5t cam .Not what I call fun to play with .Go with a 3/71 or similar ,and you will save the h***le .
  11. Desmodromic
    Desmodromic
    Sorry to go off on a related tangent. I have dreams of mounting a crank-driven 4-71 on a drag race only flathead. No good reason, except for having something unique (?). Has anyone seen such a set-up? Any first-hand tips on details of what would be involved?
  12. Full house is correct,,,,for a street setup,,,,I think a 3/71 would be more suitable.
    It would require less power to drive and still deliver what you need with correct selection of pulleys.
    The 3/71 is rated for 213 cu.in,,,,,,,the 4/71 is rated for 284 cu.in.
    Either way,,,,it will look great and will make the Flathead come alive.
    Tommy
