Hot Rods Surfacing Cylinder Heads With Sandpaper and Granite Surface Block...
Discussion in 'The Hokey Ass Message Board' started by bulletpruf, Dec 9, 2025 at 6:26 AM.
  1. bulletpruf
    bulletpruf
    I'm building a mild (9:1, maybe 325 hp?) AMC 360 on a budget and would like to surface the cylinder heads in my shop with granite surface plates. The heads are slightly warped - .0025" on one and .004" on the other (checked with a machinist straight edge and feeler gauge). They don't need to be perfect, but I'd like to get down to .001". The general spec is no greater than .001" per cylinder, so .004" is the max for a V-8.
    I bought two granite surface plates from Amazon - one Grade A 18" x 12" x 3" (about 80 lbs) and a Grade B 12" x 9" x 2". I wanted something bigger, but the 18 x 12 x 3 is the largest I could find with free shipping.
    I will not be using MLS head gaskets so I'm shooting for a 60-80 Roughness Average (RA). If I'm not mistaken, 80 grit should result in about 71 RA.
    The plan is to use some 3M spray adhesive to attach a sheet of 8.5 x 11 sandpaper to the 12 x 9 block and use it as a sanding block.
    Anyone have any experience doing this with automotive heads? There are a few YT videos that I need to watch.
    FYI - I realize that the machine shop is the way to get the job done right, but I don't want to wait for several weeks for them to get to it and I'd like to have the tools and know how to do this in the future if needed.
    Sharpone likes this.
  2. This guy did
    I’ve seen flatheads done similar
    Friend did stuff like this with brigs engines on go cars.
    Sharpone and bulletpruf like this.
  3. cfmvw
    cfmvw
    They used to hand-s****e the bed ways on machinery way back when; those old time machinists were really good! I've done it myself, definitely a process of patience and persistence.
  4. GTS225
    GTS225
    Three thousands is a lot of cast iron to remove on a flat surface with sandpaper. Sure, it can be done if you've got the arms and patience.
    Personally, I'd go for the machine shop.....Roger
    bulletpruf and hrm2k like this.
  5. 325w
    325w
    Vote for Emory cloth
    bulletpruf likes this.
  6. Greenblade
    Greenblade
  7. Joe H
    Joe H
    I have a large flat piece of heavy material, 2' x 5' x 1" thick wood with vinyl outer layers, with three sheets of heavy sand paper discs stuck to it, https://www.fastenal.com/product/details/99332155. I cleaned up a couple sets of Pontiac heads and they are still in good shape for more. It doesn't take all that long with the length of sanding material I have. With discs, there is room between each one for the grit to go so you are not moving the head through it all the time. You still need to keep sweeping the paper to keep the grit at a minimum. You also need to learn how to move the head, you push from the ends and let the weight do the sanding, pushing down and forward will not give a level surface. Go slow so the edges don't dig in to the paper. I went forwards and backwards along the length of head so all the grooves ran the same direction. The heads were installed with Felpro blue head gaskets with no issues. I have a commercial floor mat / carpet where I do the sanding, so I added sand paper to the back side of the flat wood to help hold it from sliding around. Flat home center sand paper will not last long, you need heavy emery type or self stick type paper made for commercial use.
    I gave a couple smaller sheet of paper disc to friend that stuck them to a heavy gl*** sheet and leveled out his beater car aluminum head. It worked perfect and looked as good as any machine shop cut head.
  8. Jack E/NJ
    Jack E/NJ
    from NJ
    Having the pair shaved at a local machine shop prolly costs less than the plates.:\
    Rich796 and bulletpruf like this.
  9. Oneball
    Oneball
    Back when I was young/dumb/cheap I used to use a whetstone.
    jimmy six and bulletpruf like this.
  10. Adriatic Machine
    Adriatic Machine
    I wouldn’t do it with regular sized sheets of sandpaper because the edges of the head will always wander off the edge of the paper. At the very least get a belt from a belt sander.
    You want the entirety of the surface being worked to be within the abrasive perimeter if that makes sense. Every time the head runs off the edge you’re automatically taking more material from the middle.
    X-cpe and bulletpruf like this.
  11. RmK57
    RmK57
    Getting the head flat is one thing but getting them square is another. If you have to take more off one end than the other I’m not sure how you could accurately do that without a fixture like a resurfacer has.
  12. Joe H
    Joe H
    Sanding is fine if you are just resurfacing or removing dings and rust from storage, it will not work to correct poor machining or casting flaws. My sanding fixture is longer than a head, so like mentioned above, the head never leaves the sand paper discs ( it stays on a flat plane ).
  13. FrozenMerc
    FrozenMerc
    I have done this with Ford 6.7 Powerstink valve covers. The valve covers have to be very flat because of the gasket design and the fact that the intake charge flows through the valve cover. If they aren't flat, they can leak charge air into the cylinder head rocker box, and then you end up with very high crank case pressure and a bunch of oil leaks and seal failures.
    I used an 3' x 8' Sturm cast iron surface table and some 120 grit 37" x 75" sanding belts from Grizzly. Sliced the belt, and taped it down to the surface table, and got to pushing those stupid valve covers around. It worked well as a proof of concept and confirmed that the bake oven was warping the valve covers enough during cleaning to cause air leaks.
    We weren't worried about perpendicularity like RmK57 mentioned above, and that would be important on a cylinder head. You don't want the chamber on cylinder one to end up at 69 cc and #4 be 74 cc.
  14. Dave G in Gansevoort
    from Upstate NY
    Have any woodworking friends? With one of those giant belt sander machines? Those belts are wide and long enough to cover the entire surface plate, with material to spare.
  15. bulletpruf
    bulletpruf
    I've got this one at the shop, but not quite wide enough. Shouldn't be difficult to source the right size.
    Thanks
  16. Sharpone
    Sharpone
    Poor man’s surface grinder, a couple thousands isn’t hard to achieve, no more than .004 or 0.005. Like was stated keeping everything plumb and square is very hard. I’ve used the sandpaper on a flat surface to true up exhaust manifolds and a header I built for my OT Sprite with hood results. My dad used to draw file stuff to well within 0.001. The trick to draw filing is using a very good file and letting the file do the work. Draw filing takes time and patience.
    Filing is as traditional as it gets.
    Dan
    PS 80 grit is probably the best in my opinion, I’d use copper coat also unless using mls gasket.
  17. bulletpruf
    bulletpruf
    I'll copper coat as well. Not using MLS gaskets.
    Thanks
