Hot Rods Surging at low rpm
Discussion in 'The Hokey Ass Message Board' started by 68_F100, Jun 16, 2016.
  1. 68_F100
    68_F100
    So I've been tuning in my truck after the cam swap and I noticed crusing in 2nd around 1500 rpm I get this surging feeling. Kind of like tapping the gas real fast. Is that normal with a bigger cam or something in the carb or timing? It didn't do it before the cam swap so it's something new. I hate to keep bugging you guys but everyone I know doesn't know what a carb is.
  2. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
  3. squirrel
    That's what a big cam does, makes it run rough at low rpm. could be a lean surge, could be a rich surge, my guess is lean. but I don't know everything about the engine, carb, timing, etc.
  4. Russco
    Russco
    from Central IL
    If you put a bigger cam in it it more that likely will want more initial timing for starters.
  5. Tickety Boo
    Tickety Boo
    from Wisconsin
    I agree
    Is it a Holley carb.?
    Double check for vacuum leak, put a vacuum gauge on and check to see if you have the right power valve.
    What engine do you have and cam did you install?
  6. Montana1
    Montana1
    The bigger the cam, the less vacuum signal at the metering point. In this case I'd richen the off-idle circuit. What carb do you have?
  7. 68_F100
    68_F100
    Engine is a 1970351w with 70 heads
    10-1comp ratio.
    Stealth dual plane intake
    Timing set at 12btc
    Carb is quick fuel 600 double pumper
    Vacuum is pulling 9-10 but fluctuates with the idle.
    Cam is an xe262
    RPM Range: 1300 to 5600
    - Valve Timing: 0.006
    - Lobe separation (degrees): 110
    - Intake Centerline (degrees): 106
    - Valve Lash: Hydraulic
    - Duration: Intake 262/Exhaust 270
    - Duration @ .050" Lift: Intake 218/Exhaust 224
    - Valve Lift: Intake 0.493/Exhaust 0.5
    - Lobe Lift: Intake 0.309/Exhaust 0.313
    Is degreeded straight up and has a rougher idle than I thought it would
    If I let it idle for a few minutes and the rev it it its rough the first time like it's loading up at idle.
    Overall I'm pretty happy with the cam. The bottom end feels good and pulls up to 5500. Torque curve feels pretty flat but I don't like the surge and would like to tune it out if I can.
  8. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    When your Harley Davidson motorcycle experienced surge problems,they could ALWAYS be remedied by fattening or enriching the low speed circuit.
  9. tb33anda3rd
    tb33anda3rd
    i would be curious to know if it still did it with the vacuum advance disconnected and plugged.
  10. 68_F100
    68_F100
    I'll plug the advance and see. My short list is an msd pro billet dizzy with mechanical advance.
  11. 68_F100
    68_F100
    if it goes away after unplugging the advance what does that prove?
  12. lippy
    lippy
    from Ks
    Is this an automatic or a stick. My 63 340 horse corvette never saw anything below 2500-3000 around town , course it was a stick with 4,56 gears. you guys are way too easy on these things. A little rpm don't hurt em at all, right Jim? Seemed smooth to me.:D Sometimes it is not an engine problem, sometimes it's a right foot problem. Lippy
  13. 68_F100
    68_F100
    It's a 4 speed wide ratio top loader
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Even though that's a pretty "small" cam , you're still asking the engine to operate in an rpm range the cams not happy with , the short answer is to downshift & keep the revs up where it's happy..... the long answer is an air/fuel meter & the ability to modify all the circuits in the carb [idle/transition/main] , there's no simple answer & unless you can find someone w/extensive carb tuning experience , just downshift ..
    dave
  15. 68_F100
    68_F100
    I agree it's not that big over all but the cam that came out was .442/.450 so it makes the engine much different. But my electric choke maybe messing with me. I am going to try and reset it today even though it's 80+ degrees and see if that changes anything.
  16. 68_F100
    68_F100
    So I've tried it with the advance unhooked and it's the same maybe a little worse with the stumble. It's more like it's loading up or a miss. It's fine when accelerating and is only an issue at cruse.
  17. squirrel
  18. 68_F100
    68_F100
    Yeah it's stumbling at any rpm when it's not under a load now. Won't hardly start either. I'm going to pull the carb and look for junk in it.
  19. 68_F100
    68_F100
    The carb is only 2 years old but it sits for 6 months a year and this ****py ethanol gas has probably made it nasty. I need to start filling a 55 gallon drum from the gas station 20 miles up the road that sells pure gas.
  20. 68_F100
    68_F100
    Well I found trash in the carb and a vacuum advance with a hole in it. I love reman stuff that's junk from the start
    Montana1 likes this.
