Technical SURGING
Discussion in 'The Hokey Ass Message Board' started by jimvette59, Aug 2, 2024.
  1. jimvette59
    jimvette59
    Why is my WCFB carburetor surging while I am in any gear going slow ? Can anybody help ?
  2. Confirm fuel pressure at carb inlet, vacuum leaks, and distributor advance.
  3. Do you have one of these under the carb? They've been known to cause surging :D
  4. TA DAD
    TA DAD
    from NC
    A bad vacuum advance will cause surging as it keeps adding and losing timing. unplug it and see if that clears it up.
  5. jaracer
    jaracer
    It the car an automatic or a stick? What do you mean by going slow? Is it 5 mph, 10 mph, 30 mph?? Does it surge at any other speed? Does it idle well?
  6. jimvette59
    jimvette59
    Going 5 to 15 mph ? It's A Muncy 4 speed
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    In my case (pedal car) adding timing helped a lot. “Results may vary”.
  8. jaracer
    jaracer
    Got a big cam in it?
  9. jimvette59
    jimvette59
    No stock engine.
  10. jimvette59
    jimvette59
    No the carbs. are inside and dummies on top ?
    Will do when weather gets cooler. It feels like 100 Deg. here.
  11. Tim
    Tim
    from KCMO
    I’d look for a vacuum leak
    brjnelson likes this.
  12. 05snopro440
    05snopro440
    I'm surprised nobody yet has mentioned lean surge. Are you sure it's not lean in the range you're talking about?
    When I built my 46, took it for its first drive. It has a used Demon Carb that my friend had on a 454. It was surging a lot at slow speeds, 20mph-ish. He had it jetted down from 70's that it came with to 62's. Put it back to 70's and it stopped surging.
    For surging I'd check fuel delivery and jetting first.
    chryslerfan55 and 427 sleeper like this.
  13. Doublepumper
    Doublepumper
    from WA-OR, USA
    Loose carburetor...?
    Just worked on something similar to this. Engine would run rough and surge while driving, but would idle fine.
    I found the carb was loose, with the bolts less than finger tight. Throttle action would lift the carb off the gasket just enough to cause a vacuum leak. Vacuum gauge didn't show the problem because at idle there was no throttle action and the carb would sit flat and seal. Weird one and a first for me.
    chryslerfan55 and Tim like this.
  14. jimvette59
    jimvette59
    Yes that could be it. I'll check when to weather cools down a bit. Thanks
  15. jimvette59
    jimvette59
    Thanks, I think I will put my 600 holly on.
    05snopro440 likes this.
  16. Float too high?
  17. jimvette59
    jimvette59
    Thank you all, I think It's a electrical miss. Jim T.
  18. mohr hp
    mohr hp
    from Georgia
    Is this set up new to you? Meaning, did it always do this, or is it a new condition? Knowing this could rule out tuning/fuel curve.
  19. 05snopro440
    05snopro440
    I had that issue on my 62 Chevy. At a certain throttle position, the steel throttle linkage contacted a plug wire and it eventually rubbed through an area and would miss at that speed.
  20. jimvette59
    jimvette59
    Thanks I'll look into that.
