Projects survivor old hot rod Little yellow roadster
Discussion in 'Traditional Hot Rods' started by Peterson32, Jan 31, 2014.
  1. Deuce Daddy Don
    Deuce Daddy Don
    Early attempt to make a "Roadster" out of a coupe with top removed & doors with roll up windows filled in.
    This was common back East when they could not find a real roadster.
  2. n.z.rodder
    n.z.rodder
    This is the ***s.
    Scotty
  3. Jungle Jalopy
    Jungle Jalopy
  4. 26 T Ford RPU
    26 T Ford RPU
    Or the cats meow, its just so cool. Im always amazed a how much damage these survivor cars get over the years. JW
  5. davo461
    davo461
    ...or, the dogs ******** !! Subscribed.
  6. Peterson32
    Peterson32
    [​IMG][​IMG][​IMG][​IMG]URL=http://s1330.photobucket.com/user/petersonexpress/media/Mobile%20Uploads/20140321_164414_zpseaslaj0f.jpg.html][​IMG][/URL][​IMG][​IMG][​IMG]
    I pushed the car outside yesterday !!!
    Stogy and kidcampbell71 like this.
  7. T-DeWitt
    T-DeWitt
    It looks way *****in with those hood sides on it.
  8. mike bowling
    mike bowling
    Excellent,my man- top shelf all the way-too bad that car can't talk.And your shop is pissah (east coast term for OVER THE TOP).Can't have too much "tin" in your diet. Good luck with it and keep the pictures coming.
  9. Shaun1162
    Shaun1162
    Damn that's lookin' good! The hood top does seem to tie it together... Going to leave the hood black, or blend it yellow like the rest?
  10. pitman
    pitman
    Youse some brave guys! She'll turn out fine.
  11. Squablow
    Squablow
    Really starting to look like something now. I've got an extra one of those spare tire carriers that got cut up for those cycle fenders if you need to make two more. I like the caps with the yellow paint on them too, wonder if two more could be found?
  12. Pete
    Pete
    This is one of the coolest survivors I've ever seen! That rag top is toooo cool.
    Pete-
  13. Peterson32
    Peterson32
    Yes I could use the spare tire cover !
    I have the full set of those yellow caps I plan on running those
  14. Peterson32
    Peterson32
    [​IMG][​IMG][​IMG]
    Made motor mounts tonight and tached in place its really starting to shape up now
    kidcampbell71 and volvobrynk like this.
  15. 37willysgasser
    37willysgasser
    That roadster is super cool !! glad to see another survivor!!!
  16. DeadFast 33
    DeadFast 33
    from Santa Cruz
    Look'n super cool!!! I vote for the green grill shell and insert.
    Gona be really awesome!
    FLiP
  17. Corn Fed
    Corn Fed
    Those motor mounts are very nice. Too nice for the rest of the car. You should run a bead of stick over the joints just so they aren't quite so perfect.
    Stogy likes this.
  18. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    So nice, those turned out really really well.
  19. That's what I was thinking! Hahaha!
    Posted using Full box of Crayons on the Kitchen Walls App!
  20. T-DeWitt
    T-DeWitt
    Those motor mounts looks killer.
  21. D-man313
    D-man313
    This is awesome!
  22. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
  23. ss34coupe
    ss34coupe
  24. grumpy32
    grumpy32
    from Australia
    That's a neat little roadster, must have been hidden away for years. Those gauges are cool to, or to cool ??? Wow
  25. Phastphil
    Phastphil
    This is coming together very nicely, the top setup would be killer if you could use it. I'm right accross the lake from you and I've put tops on both my roadsters, sure makes the cars much more usable in the weather we have. You've got plenty of channel even for an "east coast" car, I know it would be a lot of work, but, if you could sink the floor say 2", then raise the body maybe 2" it shouldn't really change the character but, could make it much more of a "driver" and, enable you to use that top. I just put a 500 Cad/TKO 600 combo in a prior built '29 on old duece rails, I changed a number of things a small amount, lotta work, but it was worth it in the end, car still has the same look, damn near did me in tho, did a LOT of cursing, good thing kids are grown and gone.
    Regards,
    Phil
  26. T&A Flathead
    T&A Flathead
    Thanks for showing me around the shop yesterday. Your little roadster is going to be killer.
    I will come by the shop again when I am in town.
    Tim
  27. Peterson32
    Peterson32
    Long over due update
    its coming along quite well started on my subframe just about finished
    body is mounted
    also swapped rear ends to a 46 ford and shortened the torque tube
    drilled for steering box
    Also made a middle K member and mounted the transmission
    its rolling and is starting to look less of a mock up more like a car !
    At the Round Up I picked up some old spare tire wells and started playing around with cycle fenders
  28. Okie Pete
    Okie Pete
    Looks great . Glad it is getting the loven it needs.
  29. Peterson32
    Peterson32
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    URL=http://s1330.photobucket.com/user/petersonexpress/media/Mobile%20Uploads/20140417_161914_zps7g4alna2.jpg.html][​IMG][/URL][​IMG][​IMG][​IMG]
  30. Peterson32
    Peterson32
