suspension for a 31 Model A on a 32 frame with quick change rear
Discussion in 'Traditional Hot Rods' started by rsss396, Feb 10, 2016.
  1. junk yard kid
    junk yard kid
    I used a posies ultra narrow rear spring with my quick change, 32 frame. Ended up with a bunch of spacers and a rubber strip on top of the axle. The hanger gussets would whack the frame and I didn't have much travel. Not the springs fault, and it works fine now. But lessons learned.
  2. 1946caddy
    1946caddy
    from washington
    Don't you have to move rear cross member back to maintain wheelbase?
    OOPS, missed the part about 32 frame.
  3. Yes 1946caddy, You do need to move the cross member back. If your going spring behind it don't matter what set of Frame Rails your using.
    The Wizzard
  4. rsss396
    rsss396
    Junk yard kid. Do you know how wide posies spring was this is just 1" narrower on each side
  5. Roadsir
    Roadsir
    Is that a 44 Inch main leaf? That's a nice setup.
    I used the Posie Narrow Model A rear spring that mounts on 46 1/2" Perch centres, and did not use the reversed eye spring. I removed the two short top leaves and it rides as well as a Model A spring can be expected to.
    My rear end is 57" wide drum to drum.
    LCGarage likes this.
  7. rsss396
    rsss396
    Nice setup hemi deuce! Thanks for the pic
