Suspension
Discussion in 'The Hokey Ass Message Board' started by SSD, Feb 27, 2013.
  1. SSD
    SSD
    I had a crazy idea at the gym today, now its not for the dodge although thats what inspired it maybe the wife's F1. The go-to for lowering a truck is MII or some other coil-spring and A-arm set up and 4 link in the back, now this is left field but since 50s trucks have a solid axle couldn't you use something like the 25and 3500 Dodges you know coil-springs or coil overs or air-bags and upper and lower control arms and sway-bar ect. I don't see how it wouldn't work. Any Ideas?
  2. Sure. They call it a 4 bar. Used on about 250,000 street rods. It wasn't popular until after the 60s, so it's "not traditional" by definition of the HAMB.
    Don't say you don't care...
  3. Actually for a lot of us an MII is not the go to, but that is a different argument all together.
    No reason what you couldn't just use a pair of control arms and bags or coils or whatever you want to hold it up and a pan hard bar, like a truck arm rear only pointing forward. Ford kind of did that on the coil sprung trucks, the 4WD was not a twin I beam so in essence it was the same setup like I described with a live axle.
    I would just about bet that if you looked real close at early '60s show rods you could find a set up kind if like that.
    Now if you want to think different and interesting Roth and several others used modified volkswagon suspension with a beam axle in the '60s. A little off center but off center was the name of the game in the '60s.
  4. SSD
    SSD
    thanks guys I get crazy ideas and if i don't bounce them off someone they become an obsession.
  5. Ned Ludd
    Ned Ludd
    Stick around, SSD. You haven't even scratched the surface of crazy :D
  6. mustangsix
    mustangsix
    Doane Spencer's 1948 MGTC had an Ardun V8 and a 4-bar front suspension. Built in 1948 at SoCal by him and Alex Xydias.
    http://www.jalopyjournal.com/forum/showthread.php?t=756620
