Technical SW Fuel pressure gauge question.
Discussion in 'The Hokey Ass Message Board' started by Pass The Torch, Mar 1, 2024.
  1. Pass The Torch
    Pass The Torch
    I've got an older S/W fuel pressure gauge that has the needle on the wrong side of the pin. I have no idea how it got that way; was in a box with other gauges. This happens to be of the 2 5/8 variety. Is it reparable?
  2. The pointer is simply pressed on the center pivot. If you remove the bezel and gl***, you can pull the pointer needle straight up and off and then press it back on the center stub on the correct side of the stop post.
    You can also try gently lifting the outer tip up and over the 'stop' to the other side, but that way risks leaving a bend in the pointer needle or possibly flexing and cracking off the old paint.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Unless the movement is broken .
  4. ekimneirbo
    ekimneirbo
    Could a magnet attract the hand high enough to allow it to be moved past the pin?
  5. kadillackid
    kadillackid
    I wonder if someone got the airline off a 125psi compressor to 'test' it :(
    Tim, jaracer, vtx1800 and 1 other person like this.
  6. swade41
    swade41
    from Buffalo,NY
    **** on it and see if it goes backwards
    Tim and 2OLD2FAST like this.
  7. The bourdon tube inside may have been over-pressurized, causing the needle to go past it's range., and bending the adjuster inside. These have a tiny rack and pinion set up, and they can be adjusted, but it will need dismantling.
    If you want to know how to repair it, I will show you how it's done, but it is a lot of stuff to type out here! You will need a good working gauge and a regulated air supply, at least.
    Don't just remove the pointer and put it back on the other side of the stop, then use it, you will find (at best ) the indicated pressure is way out, or (at worst) you rupture the bourdon tube.
    19Eddy30, TA DAD and jaracer like this.
  8. i7083
    i7083
    This tickled me for some reason.
    I'll probably use it, if that's ok... :D
    swade41 and Bob Lowry like this.
  9. 19Eddy30
    19Eddy30
    from VA
    Its been Over pressured
  10. Pass The Torch
    Pass The Torch
    My thoughts were that it got incorrectly "tested" at some point in it's life. The needle doesn't move freely, so it's not "broken" but obviously it's hurt. Hopefully fixable, but hurt. If the tube turns out to be ruptured, is it repairable, or is it now an ornament?
  11. Jagmech
    Jagmech
    Call John Wolf &Co. Been doing gauge repair for decades. In Cleveland 440-942-0083. If too expensive, get another.
    Tim likes this.
  12. 427 sleeper
    427 sleeper
    Did you try smacking the gauge face down, against the palm of your hand to see if you could jar the pointer back to the other side of the pin? Kind of a hack thing to do, I know, but the first thing I would try. :D
  13. The bourdon tube is made of br***, and can be soft soldered if it has a hole. Usually if it has copped an over pressure situation they will let go at the seam. They can sometimes be re-bent back and soldered, depending how badly damaged it is.
  14. fleetside66
    fleetside66
    For starters, the bezel looks like it's toast, so you may as well do what you can to get it off & start from there. Try to save the gl***, though, if it's not too scratched. Those gauges & parts are getting harder & harder to find. If it's something simple, you might be able to source a decent bezel, press it on, and you have a good gauge. You should be able to apply some gentle lift to the end of the pointer & lift it over the post. You'll know it if it's feasible ...some posts are higher than others. I know I've done it, but I can't remember what the particular situation was. Removing the pointer in an old gauge is always a **** shoot, so I'd only try that as a last resort. Once you have the bezel & gl*** off, the guts can be removed in a jiffy for inspection. The "**** test" might very well enable you to verify whether there's a hole in the Bourdon tube. Since you only have 10 PSI going, you don't need a lot of vacuum or pressure to move the needle. Did you try it? BTW, I've actually just used a dab of JB Weld to patch a tube, which worked. I was cutting through a pressure gauge cup, because the bezel was frozen, and I grazed the Bourdon tube with the cutting disc & opened a tiny hole. Let us know how you made out. I'm betting that the gauge works fine.
    Also, as a side note, I recently read that John Wolf had a stroke fairly recently, which might have some bearing on whether he's still doing gauge repair. Does anyone know for sure? I never sent anything to him, but I always heard good reports.
  15. nochop
    nochop
    from norcal
    Is the range suitable for your application? Is it rare? Looks toasty.
    427 sleeper likes this.
  16. fleetside66
    fleetside66
    Those gauge bezels were pressed in very tightly from the factory, so if there was not way for the environment to permeate the inner space, the bezel could look like **** & the face & needle could look great. They aren't rare, but are hard to find, especially in nice shape. For example, I just sold a nice on for $200. Save the old gauges.
  17. Pass The Torch
    Pass The Torch
    Here's the complete pic of said gauge. It's not all that bad - the close up made it look far worse. I haven't tried anything as of yet with regards to seeing if it would move in reverse or trying to open it; weighing options as it were. I have far other pressing things to attend to than an ill gauge, but this is on my list of things to look into at some point. thanks to all who weighed in.
