Swap for 37 ford engine
Discussion in 'Off Topic Hot Rods & Customs' started by James Bieler, Mar 14, 2025.
  1. What is this politics or a place to ask questions about your project?
    0 vote(s)
    0.0%
  2. Help
    1 vote(s)
    100.0%
  3. Help
    0 vote(s)
    0.0%
  4. Help me navigate the site please
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Packrat
    Packrat
    I would find a car that's already been hot rodded instead of tearing that car apart. I know that's not what you want to hear. I realize this is a hot rod site but some cars should be saved.
    RodStRace, SS327 and leon bee like this.
  2. RodStRace
    RodStRace
    Agreed, You dropping into this stock car and want to know how to hot rod it in your first post.
    Time and money says to move this one on and use the proceeds to buy a done car that meets your desires.
    If you want to hot rod it and want our input, lay out what you want, as @squirrel said. This could be a power tour barely street legal single digit drag car, a stock exterior with updated drivetrain and brakes, a show car, a long distance cruiser with modern comforts. You say let's make it fun, a contest. I'm not playing Guess Your Weight if I can't see you!:p
    Packrat likes this.
  3. nobby
    nobby
  4. James Bieler
    James Bieler
    Thanks caddy , lots of good advice I certainly appreciate. I was wondering are any members from missouri near St Louis ? Again thanks caddy.
  5. James Bieler
    James Bieler
  6. James Bieler
    James Bieler
    I have tons of experience
    But, I like to shoot the ****. Ask others what they think ! I dont see the harm . I figured i f you folks don't like my posts don't read them .
  7. James Bieler
    James Bieler
    Thanks my friend I appreciate.
    Packrat likes this.
  8. Roothawg
    Roothawg
    This post makes my head hurt.
    TexasHardcore likes this.
  9. James Bieler
    James Bieler
  10. continentaljohn
    continentaljohn
    As said 289 302 and 5.0 are very similar. The 5.0 is just a modern design and with a roller cam. It's a great little motor and will need some ford motorsports to shorten it up to fit into the early Ford.
    Some things to put in your shopping list would be:
    Svo short waterpump with pullies i believesterrt and performancemade them also fast times.
    A 90 degree oil filter adapter svo item as well.
    I also like the ford motorsports headers and believe ****** made them at first but changed the design. You need the drivers side to dump in the rear to clear steering and oil filer.
    A oilpan from a early bronco 66-77 with pick up will clear the drag link. I'm not sure 100% on your application as I play with 32 fords.
    While your buying bronco parts buy a smog pump alt bracket. It will mount your generator or alt low on the p***enger side.
    You can also doll up the motor to look more traditional if that the case. Blue thunder has tripower intake and cobra Shelby goodies
    Good luck with the project and great engine choice :D
  11. James Bieler
    James Bieler
    If you folks want to know more about me .
    OK I spent 28 years in USN. DID 3 TOURS OF VIETNAM ,I buy and sell repair my old cars , I am an advocational archeologist. I make forge japanese swords and knives. Am pretty fair musician , guitar piano.My archeology is from the ***tering focus.
    In the military I was chief Radarman with secondary rating gunners mate.
    Thank you.
  12. James Bieler
    James Bieler
  13. James Bieler
    James Bieler
    Thanks john for the info.
    Jim
  14. James Bieler
    James Bieler
    If you folks would carefully read , so what if I missidentified the car
    I did not come on this site to be ridiculed , I come to learn. You and your buddy a crew .
    Do yourself a favor dont answer my posts if you don't like them pretty simple.
  15. continentaljohn
    continentaljohn
    Jim anytime we can help. I will say Ford motorsports makes a wicked nice 427 aluminum small block that would light the tires up and win some races..
  16. James Bieler
    James Bieler
    This post makes my *** want to take a dip of snuff.
  17. James Bieler
    James Bieler
    Sounds bad *** what's a motor like that set me back. I know 427s are very pricey .
  18. James Bieler
    James Bieler
    I only paid 17,000 for 36 ford coupe , they gave me 22,000 cash after purchase. I could have gotten more for mustang but, I liked the old rides.
    The mustang was a Steeda.
  19. James Bieler
    James Bieler
    I checked it out , what an engine ... about 27,000$
  20. James Bieler
    James Bieler
    Caddy your ok.
    Nice to get some good advice with out the childish sarcasm .
  21. 6sally6
    6sally6
    A sailor........No wonder !!! (Me too !:D:D)
    FoMoCo stuff ain't friendly like a Shivel-lay...thx Henry !!
    You may well know Ford engines after 85 are 'mostly' roller cam motors.
    They have different valve timing than the old 302. (They have same timing as the 351 Windsor)
    Roller motors have their unique distributor cam gear. Roller cam = steel gear 302 cam gear cast.
    DON'T mix one with the udder!
    Roller motors take a different flywheel/balancer than 289/302 engines
    Intakes pans (front sump/rear sump/mid sump)will swap over.
    Water pumps swap
    distributors (with correct cam gear) will swap
    Heads (even 351W ) will swap.
    Headers (since NONE seem to fit anyway) will swap.
    Exhaust mani's will swap
    6sally6
    PS Don't let the snarky answers run you off. (You were in the Navy...you remember how everybody treated the boots/new guy)
  22. 1946caddy
    1946caddy
    from washington
