Swaping out '51 Ford pu rearend?
Discussion in 'The Hokey Ass Message Board' started by HoriCory, Jul 5, 2007.
  1. HoriCory
    HoriCory
    from Wisconsin
    The rearend in My '51 Ford pu imploded while on a road trip the other day. Right now it's about 150 miles away from home sitting in a casino parking lot.
    I was wondering if anyone had some advice as to what rearends might fit.
    I got about a 300hp sbc/th350 in it, so maybe something a little tougher than stock.
    Thanks,
    Cory
  2. fordf1trucknut
    fordf1trucknut
    A ford 9" from a 67-72 f-100 is a bolt in swap, the pinion angle is off a little but the perches line up....
    You will have to use the spring plates and u-bolts off the f-100 since the 9" housing is 3" in diameter and and stocker is 2.5" or you an do what I did and use the spring plates off an F-2 (the stock f-2 axle is 3" in dameter).
    If you find a 9.125" (looks a lot like a 9") out of a 67-72 f-100 4X4 they are 31 spline and are usually limited slip. This is the axle that I used and the stock f-1 brakes even bolted up to the axle.
  3. Hotrod F-1
    Hotrod F-1
    from OK
    What he said. I have a 9 inch out of a '58 F-100 in my '48 F-1. I bought some spring plates and u-bolts at a swap meet and used them. I put in some 4 degree pinion angle shims to get the pinion angle closer to where it should be (Just by eyeballing), but I think I would like some 6 degree shims just because. :D It has been fine so far (about 6 months of use). Good luck
  4. Deuce Roadster
    Deuce Roadster
    I would try to find a 66 or later F-100 rear because they came with self adjusting brakes.
