Technical Swapping a 2-bolt Mallory for another one exactly the same
Discussion in 'Traditional Hot Rods' started by zz29, Jan 31, 2018.
  1. zz29
    zz29
    Dumb question of the day: I’m a total novice but I now have a 29 hot rod with a 49 Mercury Flathead and a SCoT blower. It uses the shallow version of the 2-bolt Mallory distributor. The mechanic told me it wasn’t working that well. I had a spare and sent it to Bubba to be rebuilt and the thing is beautiful. So question is, can I just remove the old one and put the rebuilt one without having to do any of the things I read about timing and crankshaft? I understand how it fits, with a groove. But when I read about piston position I go all blank. Or leave it to my mechanic? Trying to learn to do the work but don’t want to mess up the engine.
  2. GMC BUBBA
    GMC BUBBA
    Yes bolt it up and run it!!!!!!!!!!!!!!!!!!!
    NO adjustment needed we do all that for you on our rebuilds........
    zz29 likes this.
  3. tubman
    tubman
    If "Bubba" set it up, it's timed correctly. The best way to time these is using a machine like he has. Unless you try really hard, it is almost impossible to put one of these on wrong, because the tab is offset. It has been done, which usually results in a broken mounting ear. Since you say you are "trying to learn", be aware that this type of distributor did not originally come on a '49 Mercury engine; they used a more conventional "post" distributor. Who ever put this together must have changed the camshaft, cam and crank gears, and front engine cover to the earlier style. Given that this much of a change has been made to the engine, I believe you should at least talk to your mechanic (***uming that he is familiar with a setup such as this). I would do some research and checking on this before diving in.
    zz29 likes this.
  4. zz29
    zz29
    I like your spirit!!!!!!
  5. christmas tree
    christmas tree
    How much total do you put in Bubba?
  6. zz29
    zz29
    So, maybe I had the wrong distributor rebuilt? The one in the car doesn’t have the vacuum brake unit and the electric cables just go into the distributor through a hole. [​IMG][​IMG]
  7. zz29
    zz29
    [​IMG][​IMG]
  8. tubman
    tubman
    Are you sure that's a '49 Merc? Everything looks like an earlier engine to me. If you really are "trying to learn", few more pictures form a little more distance and as much information as you can supply will really help. There are a lot of knowledgeable guys on here, but we need to know what we're dealing with. Light hot rod or heavy sedan? It looks like you have a very advanced setup there, so you share all you know.
  9. GMC BUBBA
    GMC BUBBA
    22 degrees at 2500
  10. zz29
    zz29
    Thank you thank you thank you. Here’s more photos. We’ve inherited his car, belonged to my father in law but he’s got Alzheimer’s now. I read in a magazine article that it was a 49 Merc and in another one a 48. We have the car now and plan to keep (unless we have to sell to pay for his care) so trying to learn but not a car guy. Maybe a distributor is not a good start? It’s definitely an racing setup. He put this motor 10-12 years ago. Before he had one with 3 Carbs on top. More pics. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Ric Dean likes this.
  11. tubman
    tubman
    Whoa! That looks like a real "top-shelf" car. Who was your father-in-law? To build a car like that (and then go from tri-carbs to a S.C.O.T. with Weber's) is about as good as it gets! If I were you, I wouldn't touch a thing until I got somebody into look the entire car over. It even looks like it has a DuVall (or similar) windshield and Buick drums! That car may be a very valuable piece of hot rod history! It would be nice to know what part of the country you're in; it might help someone identify it. I think that car is worth a LOT more tha you may think.:eek:
  12. zz29
    zz29
    We’re in New England. Yes, we aware that the car might potentially be worth a lot, and I don’t want to mess it up. I have a few people that are hot rod people I could call but trying to do it myself, but you might have a good point. It has a Lasalle Trans and the Hallibrand quick change on the back. Mag wheels that are apparently hard to find.
  13. tubman
    tubman
    A LaSalle transmission and a Halibrand! C'mon; some of you New England old-timer must know this car! I, for one, would like to know more about it.
  14. zz29
    zz29
    Ha! I think the New England old timers are gonna hunt me down and kick my *** for touching this car. To be clear, I’m not trying to change anything about the car. The current distributor is not running that well so that’s why I had the other one rebuilt, but it seems the one in the car doesn’t have the vacuum advance unit like Bubbas and im not sure how to wire it of if it will fit.
  15. tubman
    tubman
    I'd be willing to bet it's a pre-48 engine. With everything else that has been done, I wouldn't doubt it has a later Merc crank, though.
  16. Your new distributor is a points style distributor, the giveaway is the condenser hanging off the side of it. The one on the engine is likely a mallory unilite electronic distributor with full centrifugal advance, negating the need for a vacuum brake. There is rewiring to be done if you want to run the points style.
  17. zz29
    zz29
    Ohh. It starting to sound out of my league. Seems I either have my mechanic do it or get the old one rebuilt. Is points better than electronic? Or is that a discussion I shouldn’t even start? ;-)
  18. gimpyshotrods
    gimpyshotrods
    Don't start.
    Electronic is always better, but it is "not traditional".
  19. dwollam
    dwollam
    It looks to me like a '49-'53 block as evidenced by the by p*** water pumps and the bulge for them on the block. 59 AB heads. I have the early heads on a '52 block in my '40. However I do run the '49-'53 Mallory distributor. Not that much work to do the head switch.
    Lots of old school with some modern stuff like GM alternator and electric fan.
    Very cool car ya got there!
    Dave
    The temporary ugly horn is gone!
    zz29 likes this.
  20. zz29
    zz29
    I don’t want to mess with the car. Just want to get it into a nice riding shape so we can take it out on weekends. We had the water pumps rebuilt last year.
  21. zz29
    zz29
    Very cool. Horn doesn’t work in this car for some reason. Another thing to fix. It’s has the front water pumps that are engine mounts. Had a local speed shop rebuild them. They put the current distributor in but said it wasn’t performing well. I must’ve misunderstood about sending the other one to Bubba, since they’re not the same type. Thanks for the help.
  22. SkyGod
    SkyGod
    from New York
    Wow! That’s a really nice car. 1. Have fun with it. 2. try to find a street rod club in your area they should be able to connect you with a mechanic that’s knows what they are doing.
  23. zz29
    zz29
    We are pretty lucky that he’s known around here so I have a garage I can take it to and a few hot rodders that have expressed their interest to help. I thought I could do some stuff myself but I think I’ll limit it to wax on/wax off. ;-)
  24. Blues4U
    Blues4U
    from So Cal
    Wow, check out that wild intake system with the side draft Weber's. That's not something you see every day.
  25. zz29
    zz29
    Yeah, he made that. It has a metal mesh inside to keep debris out. He was a custom metal fabricator.
  26. zz29
    zz29
    Good news. My wife went to visit Helger Bros. in Little Compton and they’re a pretty known racing family and one of the guys has asked to work on the car to get running the way it should be. I’m gonna take that offer in the spring. But thank for all your comments , greatly appreciated.
  27. SkyGod
    SkyGod
    from New York
    After re reading my post I realized that It could be taken the wrong way. When I suggested you get a mechanic that knows what they’re doing I didn’t mean you don’t. Just suggesting you find someone to help and advise.
    Cheers!
  28. zz29
    zz29
    No, thank you. I didn’t take it the wrong way. Just realizing I’m over my head and last thing I want to do is some kind of expensive damage.
  29. Bam.inc
    Bam.inc
    from KS
    FYI, this is pure Hot Rod ****, your pictures may be cautiously edited or blurred out when you post, something like that. Just kidding, really cool setup. Looks like your caring for a real hot rod treasure. & hopefully his friends are willing to help keep it running for him, & you.[​IMG][​IMG]
    Sent from my SM-G955U using The H.A.M.B. mobile app
    zz29 likes this.
