Does anyone know of an electric (12v)wiper system that would work in a 1946 chevy pick up. Anything out of a used car or aftermarket would work. It needs to fit in the space where the vac*** used to go.
6 and 12V VW Bug wipers were used in lots of conversions in days past. Dunno if adaptable to your p/u.
MG roadster and Mini Cooper wiper motors are compact enough to use on a Deuce roadster, so I'll bet they work in your truck! Check junk compacts in the junkyards.
Another option is to go to Power Window Specialties. They use a european design cable setup that allows for much room. The actual motor can be mounted remotely anywhere with the cable run to the wiper ***y.wipers heres a better explanation wipers 2
Not sure if your set-up has the wipers on the cowl or above the windshiled. If the wipers are on the cowl, then I give a second recommendation to the Newport Engineering wiper motor. Used that on my 38 Chevy and installed right in place of the vacuum motor and uses the original hook-up linkage. On my 37 Chevy truck I have the wiper (only one) above the windshield, so if your 46 is the same, I think any universal 12 volt single wiper motor like sold for above the windshield mounting would work for that application.
