Projects Swedish 34 Ford Fordor
Discussion in 'The Hokey Ass Message Board' started by Tomastudor, Apr 29, 2020.
  1. Tomastudor
    Tomastudor
    Hi, looked ast this car the first time in 2013 at that I had just started my Willys project. A guy I worked with at that time showed it to, me his father owned it.They wanted to know what I thought it was worth. In 2015 I met him again and asked what happened to the car,and they still had it and it was for sale so I bought it:) Fordor 34 2 (2).JPG Fordor 34 2 (1).JPG SAM_3378.JPG SAM_3382.JPG SAM_3392.JPG
  2. Weedburner 40
    Weedburner 40
    Nice car. Should make a good cruiser.
  3. Tomastudor
    Tomastudor
    In 2017 I finally started to dis***emble the car and found rust, 20170617_115036.jpg SAM_3730 (1).JPG SAM_3733 (1).JPG SAM_3739 (1).JPG SAM_3765.JPG a lot.
  4. Tomastudor
    Tomastudor
    My first idea was to remove the body from the ch***is but I soon realised it would fall apart.
    I straightened the door hinges and reinstalled the doors the beltline was terrible, I had to lift the rear of the body with a jack and weld supporting bars everywhere inside the body. Then I started to replace floor , subrails and lower part of rear wheelwells. 20170924_192813.jpg 20171008_064741.jpg SAM_3910 (1).JPG 20171101_200310.jpg SAM_3925 (1).JPG
  5. clem
    clem
    That is a bit of a project. What you’ve done so far looks good.
  6. Tomastudor
    Tomastudor
    When I did know how much rust it was on the car I ordered cowl patch panels, rockers, door bottoms and a gas tank cover from Howell sheetmetal, it took awhile but the shipped it and I think the quality is OK SAM_3926 (1).JPG SAM_3931.JPG SAM_3932 (1).JPG SAM_3934 (1).JPG SAM_3937 (1).JPG
  7. Tomastudor
    Tomastudor
    Checking door alignment and doing more rust repair SAM_3947 (1).JPG SAM_3954 (1).JPG SAM_3955 (1).JPG SAM_3956 (1).JPG SAM_3957 (1).JPG
  8. guthriesmith
    guthriesmith
    Floors look great! I don’t envy all the rust repair. I am bogged down doing some of the same.
    Stogy and kidcampbell71 like this.
  9. 1934coupe
    1934coupe
    Tomastudor, looking good. I had a 57 Chev. once that I had to replace the same stuff, it's a lot of work.
    Pat
    Stogy likes this.
  10. harpo1313
    harpo1313
    from wareham,ma
    Been there , keep at it.
    wheeldog57 and Stogy like this.
  11. Tomastudor
    Tomastudor
    Thank you guys for the support
    Stogy likes this.
  12. Beanscoot
    Beanscoot
    "They wanted to know what I thought it was worth."
    So did you tell them 500 euros?
  13. Tomastudor
    Tomastudor
    Ha, a car with ***le is always worth money here in Sweden, I guessed about 4 to 8 tousands USD.
    His father thought it was worth much more and I was not going to buy it att that time.2 years later I got a better price not a steal but I could afford it.
  14. Mat Thrasher
    Mat Thrasher
    Looks great. I’m doing the same on a 32 Tudor right now. Replacing all the rust is a lot of work. But it’s extremely rewarding owing from rusted nasty metal to a repaired panel.
  15. Aaaand, that's how it is done! Nice job.
    brEad and Stogy like this.
  16. Tomastudor
    Tomastudor
    Continuing with the rust repair the rockers are almost done and starting with the doors. SAM_3958 (1).JPG SAM_3962 (1).JPG SAM_3963 (1).JPG SAM_3965 (1).JPG SAM_3967 (1).JPG SAM_3968 (1).JPG
  17. Sometimes I think I'm fairly handy with making patch parts, but commercial patch panels can be a real blessing; especially when you are replacing the bottom 6 inches of thin air. This '34 looks better everyday. Again, good work!
  18. Tomastudor
    Tomastudor
    Most of the rust repair is done I am sure more will show after media blasting. The drivers door had opened up at speed, it needed both rust repair and work around the hinges. SAM_3971 (1).JPG SAM_3972 (1).JPG SAM_3978 (1).JPG SAM_3980.JPG SAM_3982.JPG SAM_3986.JPG
  19. Tomastudor
    Tomastudor
    While the lower part of the body was in really bad shape the upper was good a little surface rust an very few dents. But that does not mean no work, it was badly designed just to high for my taste so I decided to chop it. Here is how I did it I found an old tread here on Hamb where a guy did it this way.
    First I removed the rear lower corners on the side windows and then I chopped the pillars and rear corners 2". SAM_4000.JPG SAM_4001.JPG SAM_4003.JPG SAM_4007.JPG SAM_4010.JPG SAM_4012.JPG SAM_4014.JPG SAM_4018.JPG
  20. Great job, I like it a lot
    Hennie
    Big mike 1968 and nunattax like this.
  21. Pitbullgoingpostal
    Pitbullgoingpostal
    Keep up the good work!
    Big mike 1968 likes this.
  22. Tomastudor
    Tomastudor
    Thanks for your friendly comments, the chopping continous more pics SAM_4038.JPG SAM_4039.JPG SAM_4046.JPG SAM_4047.JPG SAM_4048.JPG SAM_4049.JPG SAM_4050.JPG SAM_4051.JPG
  23. Tomastudor
    Tomastudor
    Getting the roof and doors done SAM_4055.JPG SAM_4063.JPG SAM_4065.JPG SAM_4068.JPG SAM_4074.JPG SAM_4075.JPG
  24. Tomastudor
    Tomastudor
    Took a look at the grille I did not think it could look good after chroming but I have sent it to a chromeshop lets see what they can do. Tried a friends seat its from a 90s Chrysler Voyager a Dodge Caravan in USA, look good I will get one. Have also checked the ridehight, looks real different when it sits right. SAM_4076.JPG SAM_4080.JPG SAM_4324.JPG SAM_4312.JPG
  25. 1934coupe
    1934coupe
    Tom I'm confused, is the time date on your camera wrong or is the car finished now and you're posting old pictures? In any case you must be young because I look at those pictures and think about all the projects that I did and now I sit on my porch with a Martini. Keep up the good work.
    Pat
  26. Weedburner 40
    Weedburner 40
    You have done some amazing work. I really like the chop, give the Fordor a little sleeker appearance.
    Big mike 1968, nunattax and Stogy like this.
  27. Tomastudor
    Tomastudor
    They are old pics the project was slowing down, maybe I am old or covid 19 I dont know so I started this tread just to remind me how much I have done and get me going again. And maybe someone would like it . And its not finished.
    Big mike 1968, 4ever18, hfh and 5 others like this.
  28. Tomastudor
    Tomastudor
    Finally I lifted the body from the ch***is, the rearend is a 59 Ford Galaxie and 36 radius rods for rear suspension. Have also done some welding on the underside of the body.
    I have filled top with a roof from a Volvo 245 installed backwards. SAM_4385.JPG SAM_4392.JPG SAM_4395.JPG SAM_4399.JPG SAM_4401.JPG
  29. brady1929
    brady1929
    Nice work.
    Stogy likes this.
  30. Tomastudor
    Tomastudor
    Got the body and ch***is mediablasted found more rust on rear wheelwells and around the cowl vent, but I wont do anything to that for now I will focus on the frame. Starting to modify for a Sbc and 700 r4 transmission. SAM_4407.JPG SAM_4412.JPG SAM_4413.JPG SAM_4419.JPG SAM_4420.JPG SAM_4429.JPG SAM_4433.JPG SAM_4436.JPG
