Projects Swedish 34 Ford Fordor
Discussion in 'The Hokey Ass Message Board' started by Tomastudor, Apr 29, 2020.
  1. Tomastudor
    Tomastudor
    Continuing with the ch***is welding it together adding boxing plates in front and rear of the X.
    The front suspension is a SoCal Speedshop forged front axle, 48 Ford split wishbones and spindles. SAM_4443.JPG SAM_4451.JPG SAM_4457.JPG SAM_4459.JPG SAM_4464.JPG
    brEad, Dave Mc, chryslerfan55 and 4 others like this.
  2. Tomastudor
    Tomastudor
    I have made a new centersection and made brackets to attach the 36 Ford radius rods.
    The rear spring is a shorted 48 Ford frontspring.
    Have also done the brackets for the split wishbones SAM_4469.JPG SAM_4471.JPG SAM_4472.JPG SAM_4474.JPG SAM_4477.JPG
  3. Tomastudor
    Tomastudor
    Put the body on the ch***is to check where the rearend should be and SAM_4479.JPG SAM_4483.JPG SAM_4489.JPG SAM_4490.JPG SAM_4491.JPG SAM_4512.JPG SAM_4514.JPG test fit radiator grille and hood.
    brEad, Dave Mc, ClarkH and 6 others like this.
  4. Tomastudor
    Tomastudor
    Removed the body and continued with the ch***is, have made the enginemount an old Hurst front of engine mount. Installed the Brake booster and mastercylinder and support rods for the radius rods. Has also made a panhard bar and brake pedal, mounted the parking brake
    SAM_4516.JPG SAM_4517.JPG SAM_4521.JPG SAM_4526.JPG SAM_4528.JPG SAM_4529.JPG SAM_4530.JPG SAM_4532.JPG SAM_4534.JPG
    Baumi, brEad, Dave Mc and 7 others like this.
  5. Stogy
    Stogy
    Sweden and Ontario, Canada have a lot in common weather wise that for sure...What a recovery...amazing, patch panels or not and I think I know the Howell secret now...:)...Glad that all worked out...
  6. Nice job on the chop and roof fill. love four doors, no waiting to take a seat. Looking better every time I stop in.
    Stogy and nunattax like this.
  7. Tomastudor
    Tomastudor
    Thanks Stogy and Charlie
    Stogy likes this.
  8. Dyce
    Dyce
    Good for you leaving it a 4dr sedan!! To many are getting cut up and made into coupes. Very nice work!!
    Stogy, chryslerfan55 and nunattax like this.
  9. 1932tub
    1932tub
    Do you have a link to the other thread with the chop you mentioned?
    I have one to do.
    Stogy likes this.
  10. mgtstumpy
    mgtstumpy
    Great build so far, subscribed
  11. Tomastudor
    Tomastudor
    The thread was "1934 4DR SEDAN CHOP. FAMILY HOTROD"
  12. 1932tub
    1932tub
  13. nunattax
    nunattax
    i love the build, with a sensible chop with practical mods looks to me like a car that will be used .excellent slightly envious.
    mgtstumpy likes this.
  14. Tomastudor
    Tomastudor
    Thank you
    Stogy likes this.
  15. birdman1
    birdman1
    Reminds me of my '55 tbird build. Everything rusted. My friends laughed and said I was nuts! Maybe they are right. I'm 74.
  16. Nicely done. As @Stogy said, Canadian cars seem to have a lot in common with Swedish cars. On a really nice Canadian car I count on replacing the bottom 6" of the car. On a rough Canadian car, the bottom 8-10 inches will require replacement.
  17. Stogy
    Stogy
    brady1929 and chryslerfan55 like this.
  18. nunattax
    nunattax
    ure welcome looking forward to the finishing touches
    Stogy and chryslerfan55 like this.
  19. Tomastudor
    Tomastudor
    I filled a lot of holes in the firewall then I modyfied it to make room for the Sbc, done some rust repair on the rear wheelwells. Made some profiles that holds up the Volvo roof then I parked my cars and went to Croatia for a holiday. 20190724_135927.jpg 20190724_135946.jpg 20190730_133619.jpg 20190731_110922.jpg 20190907_134521.jpg
    Stogy, Lil'Alb, brEad and 8 others like this.
  20. Looks really good! Cant wait to chop mine! I have a '58 Meteor station wagon roof for the insert. And a Thames grill.
    -Shiny
    Stogy likes this.
  21. Tomastudor
    Tomastudor
    Finally done the last rust repair around the cowl vent and got a Crysler Voyager seat from a friend.
    Started with the exhaust system, Chinese stainless blockhuggers with headerflanges cut away and replaced with V-band clamps, I relly like them they dont leak and are easy to remove.
    The steering box is a CCP Vega powersteering. 20191117_135605.jpg 20191117_135549.jpg 20191117_135430.jpg 20191117_135449.jpg 20191117_135514.jpg 20191117_135523.jpg
    brEad, Dave Mc, j hansen and 2 others like this.
  22. Tomastudor
    Tomastudor
    For steering column I have decided to use the right hand drive manual column that was in my Willys it has the look I want. Have also installed the Vintage Air compact evaporator, to make more room for it I have moved the dash just under 1" back and made some repair and fillied holes in the header panel. 20191118_150531.jpg 20191118_150552.jpg 20191215_105734.jpg 20191215_105748.jpg 20191215_105807.jpg 20191215_105839.jpg 20191215_105848.jpg 20191215_105920.jpg
  23. Tomastudor
    Tomastudor
    Have made a batterybox behind the rear seat and made the seat. Raised and tilted the backrest for the Chrysler front seat and some rust repair on the inner fenders. And a hatch on the floor so I can check and fill the master cylinder. 20191215_110208.jpg 20191215_110435.jpg 20191215_110615.jpg 20191215_110741.jpg 20191215_105825.jpg
    Stogy, Lil'Alb, Fabulous50's and 6 others like this.
  24. Nice work, but are you really planning on ice driving?
    Stogy, Baumi and kidcampbell71 like this.
  25. pwschuh
    pwschuh
    Everyone in Sweden plans on ice driving at some point.
  26. Tomastudor
    Tomastudor
    We have snow on the roads almost 6 months so to be a fulltime rodder you have to.
    Stogy and Barrelnose pickup like this.
  27. Tomastudor
    Tomastudor
    Testfitted the March sport track front drive system for clarence between the AC compressor and the Spal cooling fan, it is tight but it will work. Have bought a Limeworks Sprint car steering wheel and their outside mirrors and made the upper front shock mounts. 20191216_135935.jpg 20191216_135955.jpg 20191221_123723.jpg 20191221_123752.jpg 20191222_111928.jpg 20191224_122059.jpg
    Stogy, Lil'Alb, Dave Mc and 2 others like this.
  28. Tomastudor
    Tomastudor
    Decided where the AC vents would be the side ones under the dash and the middle where the ashtray was. Have made a shelf between the dash and steering column and been doing some work on the column.
    And testfitted the gastank cover. 20191225_121154.jpg 20200104_122954.jpg 20200104_123024.jpg 20200104_123046.jpg 20200104_123400.jpg 20200106_110847.jpg
    Stogy, brEad, Dave Mc and 2 others like this.
  29. Tomastudor
    Tomastudor
    Have made a fan shroud for my Spal cooling fan and checked the steering u-joint angles, the lower is 30 degrees and the Borgeson joints can handle 35 degrees, it should be fine and the steering feels smooth.
    Installed the heads and valvecovers to check that I can remove them its tight but it will work. 20200106_164210.jpg 20200106_164239.jpg 20200117_131718.jpg 20200117_131725.jpg 20200118_162334.jpg 20200118_162938.jpg
    Stogy, brEad, kidcampbell71 and 2 others like this.
  30. Tomastudor
    Tomastudor
    Test fitted the Tanks inc fuel tank had to widen the frame a little the mounting holes for the tank did not match. Sprayed epoxy primer on the ch***is made a paint box of some plastic so I would not get paint all over my garage and put body sealer on the body. I have started to ***emble my ch***is for an inspection that I have to do to get a ***le. 20200124_102839.jpg 20200124_102853.jpg 20200212_071728.jpg 20200303_101734.jpg 20200303_101800.jpg 20200303_101806.jpg 20200303_101834.jpg
    Stogy, brEad, Mat Thrasher and 5 others like this.
