Projects Swedish 34 Ford Fordor
Discussion in 'The Hokey Ass Message Board' started by Tomastudor, Apr 29, 2020.
  1. Tomastudor
    Tomastudor
    I have painted the inside of the body with epoxy primer and put body sealer undere the body.
    On the ch***is I have started with the brake system. 20200321_153003.jpg 20200303_101901.jpg 20200303_101834.jpg 20200308_151353.jpg 20200321_152954.jpg 20200321_153017.jpg 20200321_153043.jpg
    Stogy, Dave Mc, brEad and 1 other person like this.
  2. Tomastudor
    Tomastudor
    Finished the brake system and started with fuel lines and exhaust system. 20200328_134227.jpg 20200329_151833.jpg 20200329_151847.jpg 20200329_151902.jpg
    Stogy, pwschuh, Dave Mc and 2 others like this.
  3. Tomastudor
    Tomastudor
    More pics of the exhaust system and the parking brake cables are also routed. 20200331_153525.jpg 20200331_153605.jpg 20200401_230428.jpg 20200402_135336.jpg 20200403_111322.jpg
    Stogy, brEad, pwschuh and 6 others like this.
  4. Tomastudor
    Tomastudor
    Some more pics of the exhaust system and the gauges I have chosen is Stewart Warner 3 in 1, I dont think I have seen them in any car before but I like them. Have done the ash tray cover plate or AC vent cover and AC and heater bulkhead. 20200410_140354.jpg 20200410_141247.jpg 20200413_131006.jpg 20200413_143236.jpg 20200413_143243.jpg 20200413_143440.jpg 20200413_143537.jpg
    brEad, pwschuh, kidcampbell71 and 3 others like this.
  5. Tomastudor
    Tomastudor
    Last pic of the ch***is ***embled will soon tear it apart for paint. Have decided where to put the drier for the AC and made some hard lines for the evaporator and made a bracket for the brakelight switch.
    I will paint the ch***is and suspension parts in my backyard on a sunny day, 20200415_102822.jpg 20200419_120251.jpg 20200419_120327.jpg 20200423_111404.jpg 20200619_000406.jpg not this day.
  6. Tomastudor
    Tomastudor
    Some backyard painting the color I have chosen is a 60s Porsche slate gray. 20200622_093259.jpg 20200622_093307.jpg 20200622_104643.jpg 20200623_151117.jpg 20200623_151211.jpg 20200623_151220.jpg
    Stogy, Baumi, KiWinUS and 9 others like this.
  7. 34Larry
    34Larry
    This is the most masterful rebuild of a 34 that I have seen, although there are some real close seconds
    on the Hamb site. Much of what you pictured here brings memories of my build, especially the frame boxing and rework. I'd love to start another, but deteriorating health issues prevent that and so I have to live vicariously thorough the work of others. Hope I'm still around when you post the final pictures.
    Stogy likes this.
  8. bobbooth
    bobbooth
    from limeyland
    Good stuff indeed...
    Stogy likes this.
  9. Tomastudor
    Tomastudor
    Wow Thanks for your kind words this Covid 19 summer has given me time to work on my car that I normally would not had time for, so hang in there and I will work as fast as I can.
    Stogy, brEad and j hansen like this.
  10. Tomastudor
    Tomastudor
    Carefully starting to ***emble all the new painted parts, a really nice job. 20200626_094043.jpg 20200626_094058.jpg 20200704_122218.jpg 20200704_122222.jpg 20200704_122227.jpg 20200704_122239.jpg
    Stogy, Mat Thrasher, nunattax and 9 others like this.
  11. MO54Frank
    MO54Frank
    Great work.
    nunattax likes this.
  12. Tomastudor
    Tomastudor
    More parts put together on the ch***is and painted more parts black. 20200704_122252.jpg 20200704_122321.jpg 20200707_134920.jpg 20200713_114704.jpg 20200717_130522.jpg
    brEad, Stogy, Mat Thrasher and 6 others like this.
  13. Tomastudor
    Tomastudor
    Finished the brake system, fuel lines and exhaust system soon time to put the body on the ch***is 20200719_125510.jpg 20200719_125524.jpg 20200719_125540.jpg 20200719_125546.jpg 20200722_151036.jpg 20200722_151056.jpg
    brEad, Stogy, nunattax and 3 others like this.
  14. 1934coupe
    1934coupe
    Tom it all looks great, exhaust looks fantastic, my favorite exhaust materiel SS. An observation though, I think the exhaust around the MC area is going to retain a lot of heat IMO. Can you shield it from the heat? Like I said "just an observation"
    Pat
  15. Tomastudor
    Tomastudor
    Thanks Pat I have know that there might be a heat problem but I will give it a try and see what happens
    Stogy and 1934coupe like this.
  16. nunattax
    nunattax
    exhaust wrap /cheap fix
    j hansen likes this.
  17. Tomastudor
    Tomastudor
    I am soon ready to put the body on the ch***is for ever I hope, have painted the gas tank and firewall and glued rubber insulation on the frame rails. 20200802_140712.jpg 20200804_095640.jpg 20200804_153039.jpg 20200804_161431.jpg 20200804_161509.jpg
    brEad, Stogy, x77matt and 5 others like this.
  18. Tomastudor
    Tomastudor
    Now is the body on the ch***is for ever I hope, I also dont like that you only has a lock on the p***enger door therefor I have modified the driver door latch and adapted a Volvo 544 door lock. Have welded a pipe to the doorskin that holds the lock cylinder . 20200804_183027.jpg 20200804_183050.jpg 20200804_194026.jpg 20200811_154947.jpg 20200814_123444.jpg
    brEad, nunattax, simplestone and 3 others like this.
  19. Tomastudor
    Tomastudor
    I have been putting on bondo, sanding and spraying filler in my backyard when weather has been OK
    That has been my covid 19 summer 20200812_185709.jpg 20200823_101544.jpg 20200824_115720.jpg 20200827_103930.jpg 20200828_154945_001.jpg
    brEad, Stogy, Tjompen and 5 others like this.
  20. Tomastudor
    Tomastudor
    More bondo sanding filler and I have started to testfit the doors. 20200828_155015.jpg 20200828_155051.jpg 20200905_121340.jpg 20200905_123645.jpg 20200905_124929.jpg
    brEad, Stogy, R A Wrench and 9 others like this.
  21. Tomastudor
    Tomastudor
    Checking that the door latches and locks work and it is fine, the outer door handles are the original ones just a little polishing. And made a new metal part under the radiator the old one was very rusty it was easier to bend a new one. 20200905_125140.jpg 20200905_125825.jpg 20200905_130000.jpg 20200906_133101.jpg
    brEad, Stogy, kidcampbell71 and 7 others like this.
  22. Tomastudor
    Tomastudor
    Next thing is to ***emble the hood pieces they where not attatched to the car when I bought it so lets see if it fits. 20200906_133125.jpg 20200906_133135.jpg 20200907_115658.jpg 20200907_125553.jpg 20200908_132123.jpg
    brEad, Stogy, lurker mick and 8 others like this.
  23. Tomastudor
    Tomastudor
    I have removed and installed the hood many times now trying to make it fit , changing the position of the radiator adjusting the brackets the mounts the grille to radiator. It is a 3 man job but now I am pretty satisfied. 20200908_152221.jpg 20200908_152241.jpg 20200911_184254.jpg 20200913_112303(0).jpg 20200913_113328.jpg
    brEad, Stogy, R A Wrench and 12 others like this.
  24. nunattax
    nunattax
  25. Tomastudor
    Tomastudor
    Thanks
    Stogy and loudbang like this.
  26. Tomastudor
    Tomastudor
    Installed the gas tank and the steering column and u joints. Have also made the last fuel lines. My 3rd member did not have a fill hole so I drilled and tapped one. 20200912_135817.jpg 20200916_130559.jpg 20200926_120600.jpg 20200927_135230.jpg 20200927_135512.jpg
    Now I will ***emble the engine,transmission and 3rd member
    brEad, Stogy, kidcampbell71 and 4 others like this.
  27. Tomastudor
    Tomastudor
    The engine is a Chevy 350 with a .040 overbore and decked.It has Probe forged pistons Eagle crank and Procomp rods. The cam is a Compe***ion cams hyd roller and Howards lifters, Edelbrock Performer RPM heads and Performer EPS intake. 20200913_110318.jpg 20201005_182127.jpg 20201005_182217.jpg 20201006_101750.jpg 20201028_183010.jpg 20201028_183246.jpg
    brEad, Stogy, Lil'Alb and 8 others like this.
  28. nunattax
    nunattax
    hi thomas are your engine numbers machined off the block
  29. Tomastudor
    Tomastudor
    Yes they are
  30. nunattax
    nunattax
