Hot Rods Sweet, Sweet Music ! ! !
Discussion in 'The Hokey Ass Message Board' started by ClayMart, Oct 26, 2023.
  1. ClayMart
    ClayMart
    Even his neighbors must love it!
    :rolleyes:
    CSPIDY, Petejoe, Cooder2 and 15 others like this.
  2. Oneball
    Oneball
    Is the reservoir on top of the air scoop just to dump some fuel in for starting?
  3. DDDenny
    Yep, music to my ears but if he was in an HOA I bet his neighbors would piss and moan.
    When I was a teenager in the late 60's there was a guy a couple blocks away with a Dodge Charger AA/FC, I never knew it was there until he fired it up about 8:00 one night and I went running to see what it was but because it was echoing I went in the wrong direction.
    When I finally found it they were just rolling it back into the garage and the guy saw me and said I should come back the next time I heard it and he would let me check it out.
    I had already seen another Funny Car on a transporter around town but hadn't heard it run, boy, this budding hot rodder didn't have a chance after that, I was hooked.
  4. Bandit Billy
    Bandit Billy
    Camera is on a tripod obviously, and it jumps when he hits it. Love it.
  5. ClayMart
    ClayMart
    I have no first-hand experience but here's my best guess. If necessary I'm certain that there's someone here who can set me straight.
    The squeeze bottle in his hand has gasoline in it. These engines won't fire up cold with alcohol or nitro. So they get a squirt of gasoline to get the ball rolling.
    The small tank on top of the scoop has alcohol. After a short warm-up on gas the valve on the small tank is opened and allows a controlled amount of alcohol to drain out of the small pipes leading into the scoop and be fed into the engine. There are no direct lines or fittings connecting the tank to the throttle body.
    After a bit more heat builds in the combustion chambers you see him, I believe, opening a valve on the main fuel tank in front of the engine which then begins feeding nitro to the fuel pump. He then closes the valve on the small alcohol tank and removes it from the scoop as the nitro starts getting pumped directly into the engine. This is when the engine's exhaust note changes and you begin to see the header flames. And if you're in the pits watching this live it may also be when you believe it's time to "duck and cover"!
    Somebody else will have to fill in the details of the shut-down procedure. He appears to close the nitro valve at the tank. But I'm not sure if he's squirting a little more gasoline or something else into the scoop to stall the engine.
    Toms Dogs and Oneball like this.
  6. swade41
    swade41
    from Buffalo,NY
    He sure had a little pep in his step to light that off.
    My friend fires his on gasoline, once it has a little heat he switches to the alcohol/nitro mix.
    Oneball and SS327 like this.
  7. twenty8
    twenty8
    :cool::cool::cool:.........but the dude must be deaf as a post...........:rolleyes:
    jersey greaser and Ned Ludd like this.
  8. SS327
    SS327
    Big balls lighting that thing without an *** in the seat. But COOL as all hell!
    jersey greaser likes this.
  9. bubba55
    bubba55
    dang it - that's one way to heat up metal
  10. Cooder2
    Cooder2
    from tejas
    Here's some sweet music to go along with
    ClayMart likes this.
  11. jersey greaser
    jersey greaser
    the sweet sounds and smells, here's another for the lovers
  12. jersey greaser
    jersey greaser
    HHHA? . your correct. play with nitro you wind up not hearing much something i know first hand .
    twenty8 and Outback like this.
  13. CSPIDY
    CSPIDY
    Hotrod Heroin
