just wandering what i have ,the tail shaft reads 5-25-64 so would that be the year? it also reads t10-72 w.g. div r2 and the case reads t10d-1 any info would be great,thanks h.a.m.b.
Defiantely a T10 - that is the date code but there should be a letter in it. Its probably not from a chevy with a 64' casting date because the muncies were being used by then. Did they use T10's in AMC's?
how long is the input shaft? i have an amc t10. shaft measures around 8 1/2 inches. http://www.jalopyjournal.com/forum/showthread.php?t=177056
google is helpful http://www.autogear.net/pdfs/T10%20booklet.pdf shows T10D is a 63 chevy case part number
input shaft is 7 inches from the case to the tip,and it is 10 spline,i still dont know what its out of ,ford maybe chevy?
it has a chevy part number on the case, so it's probably from a chevy, eh? this is a later version of it. Notice the 4 mounting ears that stick out the sides of the case at the very front? that design is only used on GMs, so if it looks like that, it's a T-10 for a GM. not a ford or a dodge or a rambler or anything else.
