T-5 adapter
Discussion in 'The Hokey Ass Message Board' started by V4F, Nov 16, 2012.
  1. V4F
    V4F
    from middle ca.
    who makes the trans adapter for a banger to a t-5 ?? thanks
  2. jimbousman
    jimbousman
  3. V4F
    V4F
    from middle ca.
    i know them , but i need a manufacturer .............. thanks
  4. fenderhead
    fenderhead
    from Stevens PA
    D&D Fabrications
  5. hotrodA
    hotrodA
  6. Standard32
    Standard32
    from LA
  7. Wildfire
    Wildfire
    The company is Auto Restorations in Indiana
    1-800-955-3139
    You can buy the kit or just parts. I used their plate, sleave and input shaft extension only.
    The other parts came from Hot Rod Works for the open drive conversion. The lightened clutch and flywheel came from my engine builder. Driveshaft from a local shop. Juice brakes. Custom rear suspension... You get the idea.
    But the MacsSpeed bellhousing is beautiful and I would go that way if I did it again. Combo that up with a 4x4 trans to torque tube adapter from CrazyDaddyo and you would have the best of both worlds.
  8. jimbousman
    jimbousman
    The phone number was in the article:
    Auto Restorations
    (765) 288-3291
    215 W Gilbert St
    Muncie, IN 47305
  9. V4F
    V4F
    from middle ca.
    thank you all !!!!!!!!!!!!!!! steve
  10. 4-port Riley
    4-port Riley
    Steve Serr of Miller Hi-Speed makes a bell housing and a rear adapter to bolt on the torque tube.
  11. V4F
    V4F
    from middle ca.
    thanks jim .............
  12. heyitsnate
    heyitsnate
  13. Pete1
    Pete1
    from Wa.
    They are extremely easy to do yourself with only a sawzall and a drill press.
    One piece of aluminum 2 inch thick plate about 9 x 10 inches and a piece of 1/4 alum. plate.
    If you have access to a machine shop, it won't take quite as long to do.
