Hot Rods t-5 electric to mechanical speedometer conversion
Discussion in 'The Hokey Ass Message Board' started by ohiohotrods, Nov 23, 2014.
  1. TrailerTrashToo
    TrailerTrashToo
    I have a low-end Jegs/Intelletronix GPS unit that would drop out on bridges and tunnels. It also was worthless below 20 MPH (like I said "low-end"). I removed the satellite receiver and fed the speedometer with a signal from magnets on the drive shaft. I used a Rostra cruise control magnetic pickup coil - the same signal is used by my Rostra universal cruise control.
  2. gimpyshotrods
    gimpyshotrods
    Not working under 20 would be a big issue, given that much of my range is limited to 25.
    TrailerTrashToo likes this.
  3. squirrel
    To be fair, I only look at the speedo when going less than 25 mph in very few, specific situations. It's not needed most of the time.
    But I still enjoy watching the speedo needle doing it's job, knowing the archaic technology of springs and magnets and gears that make it work. There's more to it than ones and zeros...some of us can appreciate that. We're not likely to put 5 speed transmissions in our cars, either :)
    Desoto291Hemi likes this.
  4. TrailerTrashToo
    TrailerTrashToo
    As in totally worthless in a School Zone (had to mark the tach)
    gimpyshotrods likes this.
  5. gimpyshotrods
    gimpyshotrods
    My cars live in a town where they will give you a ticket for 1-over the limit.
  6. flt-blk
    flt-blk
    from Ok
    I know this is an old thread, but i had KatoKing do the conversion on my S-10 tail housing and it works great. He also made me a split ring to move the drive gear on the main shaft since the S-10 is in a different location than the Mustang one was.
    This is a picture he sent me before it was all welded up. you can see the different location of the recluctor sensor Vs the driven gear bullet . He does nice work and I recommend him.
    TZ
    sko_ford and gimpyshotrods like this.
  7. JoeMan
    JoeMan
    Can KatoKing message me please?!? Or someone help me get in contact? I can't :( and I have a customer needing this conversion done to his T5. I'd appreciate it KatoKing!!! And I live in the state next door:D
  8. pprather
    pprather
