T-5 gear ratios
Discussion in 'The Hokey Ass Message Board' started by BHoover, Mar 31, 2013.
  1. BHoover
    BHoover
    from Neosho MO
    I need help figuring what low gear is in my T-5? Any body have an educated way?:confused:
  2. need louvers ?
    need louvers ?
    is it out of the car?
  3. Texas Webb
    Texas Webb
    And what did it come from.Check T-5 tech by flat ernie on here.
  4. chopt top kid
    chopt top kid
    All Borg Warner t5's had a metal ID tag bolted to the transmission with one of the bolts that held the tailshaft housing to the gearcase. The tag will have a number: 1352-**x. Find the number on the ID tag on your t5 and look it up here:
    http://www.britishv8.org/articles/borg-warner-t5-id-tags.htm
  5. gimpyshotrods
    gimpyshotrods
  6. Cerberus
    Cerberus
    Choptopkid- that chart is awesome!
  7. Normbc9
    Normbc9
    Look at the T-5 section at www.inliners.org Great information. You'd be surprised at just how many variants there are.
    Normbc9
  8. V4F
    V4F
    from middle ca.
    you need the #s off the trans tag !
  9. blowby
    blowby
    from Nicasio Ca
    Put it in first, spin the crank or the input shaft one turn and see how many times the output shaft turns.
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    It's a lot easier to spin the output shaft one turn and count the input shaft revolutions. :D
  11. need louvers ?
    need louvers ?
    Exactly what I was getting at earlier before dinner interupted my train of thought...
  12. BHoover
    BHoover
    from Neosho MO
    It is out of the car and in pieces on the bench.1st gear has 32 teeth and cluster for first has 14 teeth.
  13. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Gotta know how many teeth are on the input shaft gear and the front gear on the cluster also to figure the first gear ratio but easiest way is to get the number off the tag
  14. BHoover
    BHoover
    from Neosho MO
    It does not have a tag.
  15. BHoover
    BHoover
    from Neosho MO
    The input has 21 and the cluster has 37.
  16. Kerrynzl
    Kerrynzl
    I just did the math for you!
    It is a 4.0272:1 first gear [ probably S10 ]
    so it should be
    1st – 4.03 2nd – 2.37 3rd – 1.49 4th – 1.00 5th – 0.86
  17. treegrower
    treegrower
    from VT
    I bought a Camaro T-5 before knowing how many variations there are. I wanted a 3:1 1st gear ratio, and didn't realize that that ratio only comes from the factory behind an 8 cyl. 6 cyl engines come with a 4:1 ratio. Finally tired of the granny low and swapped in an MY6--great improvement.
  18. gimpyshotrods
    gimpyshotrods
    That is the one that I am planning to put in my Falcon.
  19. BHoover
    BHoover
    from Neosho MO
    Thanks for the help found out it is turbo 4 cylinder t-5 out of a thunderbird. It is a world cl*** trans.
  20. Flat Ernie
    Flat Ernie
    Tech Editor
    Those have a unique input shaft - longer and spindly-er than any others. Difficult to adapt to few things but the 2.3. Take a picture of the tailshaft and post it if you would - I've always been told, but never seen, that the shifter is slightly forward of the Mustang position...of course, heard this was for the V6 Super Coupe, but I'd ***ume it would hold true for the Turbo Coupe as well...
