I am just starting this project and any info on problems or pointers would be greatly appreciated. It's a 216/ three on the tree and a foot starter too. Can I use the original clutch or do I have to go to a Vega clutch disk to fit around the foot starter???? Sent from my iPhone using The H.A.M.B. mobile app
Clutch disk hub will have to match the T 5 There is an adapter to bolt the T 5 to the early small pattern bellhousing. 191851028189 in an Ebay search will find it or you can go to their website by putting the name on the adapter in a search. You will need to swap rear ends and there you probably want to go with an S-10 4c4 3.7 rear axle or a 3.7 out of a Camaro Someone was doing an adapter to run a T 5 with the closed drive rear but that gets pretty involved for most guys.
I have used products from these guys, and am nothing but pleased: http://www.hotrodworks.com/product/1940-1954-chevrolet-t5-transmission-adapter/ If you are handy, you can roll-your-own transmission mount, or buy one from them, too. All of the clutch components can remain stock, and the foot starter can remain. Only the splines in the middle of the clutch disc need to match the transmission input shaft, and the disc diameter match the original one. I have used the advice of HRW: "Please note: ...A new clutch disk (Sachs p/n BBD4203, not included) is also required. We also recommend using a 75” speedometer cable (NAPA p/n 615-1605, not included)." That is a clutch disc for: Make Model Year Engine Type Application Note Detail Color Chevrolet Camaro 1984 - 1986 L4 2.5L 2474cc Standard (N/A) (N/A) Chevrolet Camaro 1985 - 1989 L6 2.8L -cc Standard (N/A) (N/A) Chevrolet S-10 1990 - 1993 L6 2.8L -cc Standard (N/A) (N/A) GMC Safari 1985 - 1990 L4 2.5L 2474cc Standard (N/A) (N/A) GMC Sonoma 1991 - 1993 L6 2.8L -cc Standard (N/A) (N/A) Jeep Cherokee 1985 - 1986 L6 2.8L -cc Standard (N/A) (N/A) Jeep Comanche 1986 - 1986 L6 2.8L -cc Standard (N/A) (N/A) Jeep Wagoneer 1985 - 1986 L6 2.8L -cc Standard (N/A) (N/A) Pontiac Firebird 1983 - 1986 L4 2.5L 2474cc Standard (N/A) (N/A) Pontiac Firebird 1985 - 1989 L6 2.8L -cc Standard (N/A) (N/A) GMC S-15 1990 - 1990 L6 2.8L -cc Standard (N/A) (N/A) Chevrolet Astro 1985 - 1990 L4 2.5L 2474cc Standard (N/A) (N/A)
Here is a magazine write-up: http://www.hotrod.com/articles/1101sr-putting-a-five-speed-in-a-49-54-chevy/ Pictures are at the bottom.
Thanks guys for the great info and it is already helpful!!!!!!!! Sent from my iPhone using The H.A.M.B. mobile app
The T5 transmission will not work for you because of the torque tube Rearend . But all you need to do is swap in a open drive line rearend from a '55-'64 chevy or a ford 9". Probably the clutch too. Sent from my iPhone using The H.A.M.B. mobile app
I am having trouble with the enclosed drive shaft where the bell slides down from the ******. Can I just cut it so I can get to the u- joint????? Any help would be great Sent from my iPhone using The H.A.M.B. mobile app
I got my ****** in and all done and I wanted to know if Chevy or any other maker made a steel wheel that is 16 with 5 bolts and is 4 and 3/4? Sent from my iPhone using H.A.M.B.
The aftermarket is full of them. You can pick you width, and frequently the accommodations for what wheel cover/hub cab you want to run.
Thanks again for the info and I might look at speedway and see if they have anything Sent from my iPhone using H.A.M.B.
