t-5 trans
Discussion in 'The Hokey Ass Message Board' started by billy o 29, Jul 28, 2009.
  1. billy o 29
    billy o 29
    picked up a t5 trans from a v6 camaro today after getting it home i did more studying to only find out this case is the ford bollt pattern i was wondering if anyone is making an adapter or bellhousing for this wc trans there is a ton of them out there.
  2. scottybaccus
    scottybaccus
    The V6 ****** is not V8 friendly. Search T5 and look for all of Ernie's writings.
  3. billy o 29
    billy o 29
    thats too bad i will have to make my own adapter hmm maybe there will be enough demand for these to make a few this is a wc transmission that are readily available for hot rodders
  4. rustyford40
    rustyford40
    from Mass Bay
    Is the t-5 an overdrive transmission?
  5. Mattilac
    Mattilac
    Yep 5th is overdrive.
  6. spooler41
    spooler41
    Billy o, if you are going to use this T5 behind a sbc , you should be able to use the V6 bellhousing,it has the same engine side bolt pattern. Wait that's only correct if it was a 4.3 V6,if it was a 2.8 ,you are back in the woods.
    Sorry if I dashed your hopes. Jack
  7. silent rick
    silent rick
    you don't mention what engine you want to adapt it to.
  8. SteadyT
    SteadyT
    By 'WC' you mean 'World Cl***' right?
    If so, its V8 friendly (may likely not have come from a V6 if it is a World Cl*** T-5)
  9. Flat Ernie
    Flat Ernie
    Tech Editor
