T-5 transmission mount? what should I use?
Discussion in 'The Hokey Ass Message Board' started by dorksrock, Oct 4, 2007.
  1. dorksrock
    dorksrock
    Ok all you guys running T-5's! I need to know what transmission mount to use for my T bucket project. Its a '91 S-10 transmission. Should i use the stock type mount, or is there a diffrent mount off of somthing else that works better, or aftermarket mount :confused:? Tried a search, but didnt feel like looking through all 500 results!:rolleyes:
    thanks!
    Jordan
  2. Retrorod
    Retrorod
    I use a stock replacement S-10 two wheel drive part, works very well, easy to mount........in fact I used two of them to mount the flathead engine in our roadster as well.
  3. dorksrock
    dorksrock
    Does it look like this, because this is what I get on napa online.
    Jordan
  4. dorksrock
    dorksrock
    also how does it mount to the transmission, those two holes on top with bolts to the tailhousing and the single bolt through the crossmember?
    Jordan
  5. Dirty Dug
    Dirty Dug
    That's how I did it.
  6. dorksrock
    dorksrock
    ok, Im going to my local napa! be back later!
    Thanks guys!
    Jordan
  7. 53sled
    53sled
    from KCMO
    I used that one, welded a piece of angle iron to the stock x-member and drilled a hole. done.
  8. dorksrock
    dorksrock
    Just got back from napa. Cost me $8.91 after tax. looks pretty slick, and I can think of several other uses for it at a price like that! Ok, im going out to the garage to build a crosmember!
    Jordan
  9. Retrorod
    Retrorod
    That's why that same part is "in stock" in my shop........I use them for everything.
