Projects T 5 transmission
Discussion in 'The Hokey Ass Message Board' started by treegrower, Nov 11, 2024.
  1. treegrower
    treegrower
    from VT
    I'm back after a 20 year hiatus with a new project. I wish to convert the original transmission in my 1930 model A huckster to a T5. After reading multiple threads on the Ford Barn I know I need a trans with a Jeep CJ shifter extension--the shortest possible T5 configuration. I have found a trans with a casting no of 1352-065-904. It is advertised as a Jeep trans, but the number shows as a Ford NWC or Astrovan. Is it possible--even likely- that this unit was common to both Fords and Jeeps? My main interest is the shifter extension which has a casting no. of 1351-066-902. This no. is not listed on the web page I found (http://www.pro-forceperformance.com/t-5_identification.htm). I have a good S 10 trans to which I wish to attach the Jeep shifter. Corollary question--will the shifter extension from an AX Jeep trans fit onto a B-W T5?
    Tow Truck Tom and chryslerfan55 like this.
  2. krylon32
    krylon32
    from Nebraska
    If you are doing this to a stock type car check Miller High Speed Heads. Dan good T5 conversion parts plus he's a nice guy.
  3. Mr48chev
    Tow Truck Tom likes this.
